Car Issues & The Dealer
alright well recently my car had been acting funny and in a few instances went into a fail safe mode (02 lx auto..mods presently on the car magnaflow cat-back only) but it stopped doing the fail safe stuff but would do it again while going slow or slowing down but now it doesn't do it at all, but it still acted funny i.e. cuts on and off during idle, sometimes during slow driving (0-30 mph), and in one instance it would not shift out of first and reved real high so i stopped the car, turned it back on and it was normal again. i took it in and they claimed my problem could be caused by my aftermarket alarm which was installed after the problem started and they said they would not touch it
. so i had it removed and the problem still occured and even started to get worse so i took it in again but now they say they couldn't find any problems registered on the computer and will charge 75/ hour changing parts untill the problem is installed and that the warranty may be voided because of the alarm since it was wired into the cars wiring..more
alright i'm not to sure if the sema law stuff will help but i guess it's worth the try. also has anyone experienced this kind of problem with their car? oh and to make it be known i don't not drive it hard nor do i neutral drop or anything stupid in that nature.
alright i'm not to sure if the sema law stuff will help but i guess it's worth the try. also has anyone experienced this kind of problem with their car? oh and to make it be known i don't not drive it hard nor do i neutral drop or anything stupid in that nature. Wow that really sucks man. First off you should find another Honda dealer to go to.
It seems your car might have been affected by the car alarm. My dad has been an auto mechanic for 20 years now, and has seen far too many electrical problems associated with bad electrical work (IE: cutting of OEM wires to splice and solder). If the car did go into limp mode then you wouldn't be able to go ver like 15mph (has this happened to you or was it just the car acting funny).
AGAIN take it to another Honda dealer and try your luck there.
Originally Posted by Ramones
Wow that really sucks man. First off you should find another Honda dealer to go to. It seems your car might have been affected by the car alarm.
Nah man the problem began before the alarm but honda is still tryin to put blame on it. anyone have other suggestions?
Since you already took off your aftermarket alarm, take it to another dealership where they dont know that you had a aftermarket alarm. Then tell them you have no idea what the hell is going on.
Usually dealers say the warranty is still good as long as the alarm is professionally installed. I doubt it's causing your problem, unless there are loose wires shorting out all over.
Originally Posted by streetglower
ok good, you live in h-town, well close to it, exactly where. Ok and what dealer are you going too?
i got my car from gillman in richmond and i think you know where that's at, and i could take it to someone else.
awesome i'm gonna see what happens and i'll start goin there. i told my dad and he said that he might take my mom's pilot there if it ever needs anything cause even he thinks what they are tryin to do is bullsh!t .
awsome i'm gonna see what happens and i'll start goin there. i told my dad and he said that he might take my mom's pilot there if it ever needs anything cause even he thinks what they are tryin to do is bullsh!t.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
