Tranny Problem?
Old Aug 13, 2004
Wolfgang5884's Avatar
Exclamation Tranny Problem?
I think my tranny is having problems. Sometimes when I shift into 2nd gear it pops out. WTF is going on. It rarely happens but it scares me a lot. Anyone have any idea what the problem may be. I'm taking it to Honda on Monday.
Old Aug 13, 2004
AR's Avatar
AR
e-married to daydreamer
Pops out... without your hand on the shifter?
I have heard of this being a problem with some of the 2k1 civics.
IBTM also.
Old Aug 13, 2004
whats IBTM stand for?
Old Aug 13, 2004
In before the move to vehicle issues forum. This is a known problem and should be under warranty or tsb.
Old Aug 13, 2004
Honda said if it doesn't happen during the test drive they can't do anything about it, are they in me?
Old Aug 13, 2004
streetglower's Avatar
who cares what the problem is, honda will gladly fix it if it is under warranty.
Old Aug 13, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
may not "gladly" fix it lol.. but they will eventually after telling you it's because of your window tint.. and if you don't get it, think about it..
Old Aug 13, 2004
I put an aftermarket shift **** on, should I put the oem one back on?
Old Aug 13, 2004
that doesnt matter, a shift **** wouldnt have anything to do with your tranny messing up.
Old Aug 13, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
I took the TBS with me just in case they say that they never heared of the problem.
Old Aug 13, 2004
i know that isn't causing the problem but will they give me some Sh*t about an aftermarket ****?
Old Aug 13, 2004
honestly, it all depends on the dealer, I doubt it though. That wouldnt directly affect your tranny in any way. If they do, tell them to shove it.
Old Aug 13, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I will put as much as stock parts back as possible. Before I had some problem with my light they were bithing about my aftermarket stuff and won't fix it under warrenty. End up paying $300 to fix at a shop.
Old Aug 13, 2004
Ok, i'm just worried that if I don't get it fixed soon it will really mess up my transmission. I heard some dealership stories consisting of voiding the warranty. Maybe I'm just paranoid. Thanks a lot for the info, I appreciate it. I'm sure glad I found this site.
Old Aug 13, 2004
Ok, i'm just worried that if I don't get it fixed soon it will really mess up my transmission. I heard some dealership stories consisting of vioding the warranty. Maybe I'm just paranoid. Thanks a lot for the info, I appreciate it. I'm sure glad I found this site.
even if it really messed it up, your warranty will cover it. So dont stress about it.
Old Aug 14, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I blew my tranny @ 40k honda fixed it and didn't ask for a penny
Old Aug 31, 2004
CtrlAltDel's Avatar
CtrlAltDel is an unknown quantity at this point
does this "pop" hurt anything at all ? if i dont have a warrenty with honda (bought used) would i have to pay ? or ?
help
Old Aug 31, 2004
help
Well can I ask why you didnt get a warranty with your used car? Even if you didnt buy it at honda, you should get an extended warranty. And the car should come with some type of limited warranty I hope.
And yes you would have to pay if you have no warranty.
Old Aug 31, 2004
7Gnoob's Avatar
help
What year is your car? You may have some factory warranty left. My girlfriend's used 2001 civic had the balance of the 100,000km power train, they rebuilt her tranny for free. Take the TBS sheet with you. They know about this problem.
Old Aug 31, 2004
CtrlAltDel's Avatar
2001 ... i have a warranty from the car place i got it from ... and its limited yes ... just wondering if that would cover it ... i'll make some calls ... would the factory warranty (if any left) apply to me?
Thanks
btw does this damage the tranny?
Old Aug 31, 2004
7Gnoob's Avatar
Yes the factory warranty will cover it, it's transferable through owners. Like I said before, my girlfriend had her's rebuilt from honda and her car is a used 2001, bought this year. You just have to make sure you still have warranty left. 4 year/ 100,000 km over here in Ontario. Yes this will damage your tranny everytime it pops/grinds out of gear. The gear teeth are sharp, everytime they pop out they get rounded.
Old Aug 31, 2004
7Gnoob's Avatar
Here is the TBS.
http://www.nhtsa.dot.gov/TSBScans/sb626650.pdf
Old Aug 31, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
anyone having a problem with the 04'z...I think my first gear is doing this...but not always
Old Aug 31, 2004
Thanks
Well it all depends on how many miles you have? And what warranty? If you have the powertrain warranty, then yes it will be covered.
Old Sep 1, 2004
RedRider's Avatar
RedRider is an unknown quantity at this point
I had a 2K1 with 28K on the odometer when it started popping out of second gear. After a while it started popping out of 5th too. TOok it to the dealer and shift cables need to be replaced. It was covered under warranty. It did take about 6 weeks to get the cables in so be prepared for a wait
Old Sep 3, 2004
rjcmstar's Avatar
rjcmstar is an unknown quantity at this point
Yes, my '04 does this. About 20% of the time in reverse, just under 5% of the time in 2nd & 3rd. I think the problem is crappy syncros. There are times when the tranny just won't go into reverse all the way without first shifting into a forward gear. It will
go in far enough so that you *think* it's in gear, when it's really only partially engaged. I have a similar problem with 2&3 in that it's easy to get a partial engagement. Sometimes when you shift into 2 or 3 you need to apply a little more pressure to make sure it engages the rest of the way (almost like a dual engagement). As a result, shifting into 2nd&3rd is not a standard movement. You need to give it a little more umph after the initial engagement to make sure you get it fully engaged. Bottom line is that you can't have a clean, standard movement for shifting the car or it will pop out of gear on you at times. Generally, it's a smooth tranny, but it can behave in a very rude manner at times. Our '95 did this too. I had hoped that they would have fixed it over the past decade, but, they didn't.
Has anyone figured out how to down shift into first while the car is moving? This is the most anoying tranny quirk. You approach a red light, you're slowing down to 5mph or less, the light turns green, and you want to down shift into first and go. I don't think God could shift my car into first without coming to a full stop. The shifter just won't budge when moving it towards first.
Old Sep 3, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
^^^ Jeez.... rev-match the engine and pop it in first. If you know how much to tap the gas when you shift it'll slide right in. Takes a bit of practice.
Old Sep 8, 2004
rjcmstar's Avatar
I always rev match. Works well in most other cars, but, not for first gear in either of the Civics I've owned. I've even tried a true double clutch (Depress Clutch, shift out
of 2nd into neutral, release clutch, depress clutch, rev match, try to move shifter
into first, won't budge, curse). I know the tranny will last forever (although my
'95 had a throwout bearing seize at 70K making for one very challenging drive home); one just has to live with it's downright quirky behavior.
Old Sep 8, 2004
SukitNicenSlow's Avatar
SukitNicenSlow is an unknown quantity at this point
I have a 02 with 8,380 miles on it. Transmission went to ****, so did the piston rings, and so did the clutch. I got it back yesterday after 2 weeks. Not a penny out of my pocket. I got an extended warranty too. Im covered till 100,000 miles
Old Sep 8, 2004
Did you drive your car hard or something? I still dont understand how trannies can go that fast. Not to mention piston rings. Sounds like you raced it or something.
