auto tranny problem
well last night i was kinda drivinng hard and i was nuetral droping one or to times and after that i drove to my friends house and i tryed to put it park and it would not go in to park so i was like ok there is something rong i tryed to pull the key out when it was park and it did not come out so it was like it was not in park but the shifter was all the way up and i could not take the key out so i tryed and i tryed and i got the key out.
i put the key in and i try to start it in park but it would not start so i put it in nuetral and it started so i dont no whats rong with it.
help
help
The gears got messed up. It won't let you remove the keys if the car isn't in park (or if the ecu doesn't think it's in park). I hope you have warranty, because it could get expensive. If you like driving hard, get a tranny cooler. Regardless, you shouldn't be doing neutral drops.
neutral drop= no good
our civics arent made with the best trannies..keep that in mind when "neutral dropping" yea hopefully u have warranty and they can fix that sucka. if not, lesson learned.
well i went to honda today and droped off my car and the guy called me back and said the subframe was bad and need to get a new one so i said ok he was like it will be 273+labor i was like dam.
What the hell is a subframe?
you are better off buying a use tranny, like a local junkyard then take it to good shop. Honda is going to kill you for their service and prices.
You got to do it more then 2x of N's drop to kill you tranny that easy.
MajTom
Jun 2, 2015 11:48 AM
bo_red
May 26, 2015 07:25 PM
02Si
Dec 14, 2001 10:26 AM
