engine malfuction light on?
Old Aug 6, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
#9 blu/blk-VTEC Oil pressure switch VTEC ONLY
i was using this to tap this wire (dunno why, just tinkering) using a vampire tap for an LED (like a VTEC light but not goin off the solenoid wire). when VTEC was supposedly to engage (i was light on the gas in second, around 3100rpm), the engine malfunction (not CEL) came on. hmmmm what the heck is wrong?
right now ive disconnected the LED for that wire as well as for the vtec solenoid wire (so theres like a wire tap on each wire (VTEC solenoid and oil pressure switch thats empty)). help!!!
EDIT: at first i thought VTEC wasnt engaging, but then the car doesnt seem any slower... the light coming on (as said in the user manual) says that something is wrong with emmisssions control?
Old Aug 8, 2004
skarteez's Avatar
nobody? i need help bad...
Old Aug 8, 2004
You need to find out what code is setting off the cel. Then go from there. I don't know exactly what you did by tapping wires. Malfunction and CEL (check engine) are the same thing. Maybe you blew a fuse or just messed something up. Pull the battery and plug it back to reset the computer. If the light stays off, you're good.
Old Aug 8, 2004
skarteez's Avatar
eh for some reason after "untapping" everything and driving around, it just turned off....
go figure
thanks anyway gearbox, never knew malfuction and CEL was thesame. thanks!
hernandexz
Oct 28, 2021 10:52 PM
CarStuff
Dec 6, 2020 12:52 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
supercivic01
South
Nov 30, 2001 11:27 AM
