air intake system
Old Jul 25, 2004
benj's Avatar
benj is an unknown quantity at this point
air intake system
He guys give me some advise.
I am thinking to install a now air intake system for my 99 civic se instead of the factory one. cause some people told me that will increase 10-20 hp. Is that true?
Does it worth to spend couple hundred bucks on it? and if it does, which brand is the best for my baby.
Thanks I appreciate.
Old Jul 25, 2004
At least on our cars, intake only gives 1-2hp. I would just keep the stock intake.
Old Jul 25, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
if you have a 99 civic, get J's racing intake or any imitation of that. It's not a CAI, but it gives the best gains over any intake including AEM
if you don't believe me, Honda-Tech.com
Old Jul 25, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
dont do anything until adequate research has been done. 20HP is a lie........... 10 is rarely believable.......
Old Aug 13, 2004
bel's Avatar
bel
bel is an unknown quantity at this point
1-2hp Is Likely Bro, Dnt Believe Anything Higher Than That!!! Its Just Good Advertising!!!!
Old Aug 14, 2004
HELP_ME's Avatar
HELP_ME is an unknown quantity at this point
i would just get it for the look...
Old Aug 14, 2004
shmik1's Avatar
looks and sound..
Old Aug 15, 2004
Lilies247's Avatar
Lilies247 is an unknown quantity at this point
please keep the stock in there!!!!! I had a cold air intake installed about 9 minths ago and just last week my engine hydrolocked and now I have to get a new engine. So I would advised against it. So if something were to happen warrenty doesn't cover and very rarly would your insurance cover it. I was lucky that they did
Old Aug 15, 2004
air intake systems can be either cold air or short ram.. short ram takes air from inside the engine bay whereas a cold air sucks air closer to the ground. i got a short ram because i had/have a big *** fear of hydrolock. anyways, back on subject, 1-3 HP is likely from any intake, so like everyone has said, get it just for the looks and the sound, and dont expect too much out of it
Old Aug 15, 2004
PunkingCivic's Avatar
I need TP for my bunghole
I'd say 5 to 8 HP from an intake upgrade.
I'd agree with aznboysrfr, get a cheap one.
The intake will also increase the gas milage.
I suggest getting a K&N filter if it come with a stainless one.
Check ebay and get a used one or generic brand.
here use the link to view the search results for "99 civic intake"
http://motors.search.ebay.com/99-civ...trypageZsearch
Old Aug 27, 2004
rEkKaShInObI's Avatar
Unsalvageable
so most intakes dont increase much power, but do they increase MPG (miles per gallon)?
Old Aug 27, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Well...for me I never get the extra mileage...I end up wanting to hear that engine scream so I usually get lower miles per gallon, somewhere around 34-35...but when I drive on the highway I get around 40mpg...also synthetic oil helps a lot with the MPG if that is what you are looking for...
Old Aug 27, 2004
Unsalvageable
that kinda helps, a little... doesnt exactly answer the question.
Old Aug 27, 2004
I had the K&N fipk and got 32mpg all highway. Switched back to stock and got 38mpg. Low end torque will decrease with an aftermarket intake, but you may gain a few hp up top.
Old Aug 29, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
5-8 Hp is a lot when your starting out with 115-127 ! Jeez!! of course buy one. You will feel the difference. i have found that intakes need some tweeking to get the best all around performance. example shortening my AEM SRI made a world of top end difference without losing any low end TQ.
Old Aug 29, 2004
shortening your aem sri? why?
Old Aug 29, 2004
Wolfgang5884's Avatar
if your lucky 1-3 horses
Old Sep 1, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
run the stocker just get a good filter for it.
Old Sep 14, 2004
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
what is the best short ram to buy? so far ive been hearing AEM V2. let me hear what you think
Old Sep 14, 2004
No, it's the K&N fipk. I just got mine from robearracing. It has a heat shield and smaller tube than AEM. This means colder air and better low end than AEM. Design is just better imo.
Old Sep 14, 2004
is the K&N a short ram though?
Old Sep 14, 2004
Yeah it is. Does it matter or do you have to get cold air. You'll get similar results with either one.
Old Sep 14, 2004
davidoff1's Avatar
davidoff1 is an unknown quantity at this point
wat do u guys think about this?
http://www.bmcairfilters.com/infoCDA.asp
Old Sep 14, 2004
Interesting, but I see alot of warnings and nothing specifically for our car.
Old Sep 14, 2004
davidoff1's Avatar
i guess intake below 1.600 CC should work for our car
Old Sep 15, 2004
i heard the K&N is basically silent unless you are cruising at about 85 mph, but i also heard the V2 sounds like ****. Do u Know anything about either?
Old Sep 15, 2004
My K&N fipk can be heard even when accelerating to 3500rpms. Basically if the pedal is pressed down almost 1/2 you will hear it. Only way not to would be keeping it below 3k rpms. On the freeway it's silent at 65mph, but give it some gas and you'll hear it. I think it's alot louder than stock. Once I get my new S&B filter, I expect it to become even louder.
Old Sep 15, 2004
thecheat's Avatar
you should by my used cold air that I converted to short ram for $20
Old Sep 16, 2004
i just ordered the V2 yesterday, however i didnt pay for it yet. If anyone has a severe reason for me not to purchase it when it comes in, please tell me now! thanks
Old Sep 16, 2004
I think the V2 is comparable to the fipk. The design is alot better than the original AEM, so it should be good. Can always swap for a better filter later.
