Auto-Lock/Unlock not working for driver's side door
Old Jun 21, 2004
AzNxTc's Avatar
AzNxTc is an unknown quantity at this point
This problem just surfaced a couple days ago when I realized that when I was locking my car with the factory remote entry, my driver's side door wasn't locking (the lock thingy wouldn't go up or down automatically). it doesn't respond to the interior lock/unlock levers either. I don't know what's wrong and how I can fix it. Any ideas? Or should I bring it to Honda? Any help is greatly appreciated.
Old Jun 22, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
streetglower has the same problem :
http://www.7thgencivic.com/forums/sh...d.php?t=159866
I would take it in to the dealer if you still have warranty on it
Old Jun 23, 2004
streetglower's Avatar
Yea this **** is a pain in the ***? I can take it to honda because it is covered by warranty, but I have to pay $100 deductable, or I could get the actuator from majestic honda for $17 or the locking assembly for $32 but dont know if that is the problem.
Old Jun 23, 2004
CivicsRdBest's Avatar
hmmm it's most likely mechanical if both won't work. So I suggest letting them take a look @ it.
Old Jun 24, 2004
TonySTiX's Avatar
TonySTiX is an unknown quantity at this point
I have the same problem right now with my car also.
I took off the panel today and looked at it and tested everything out..
Its definetly not mechanical...It is most likely the actuator, which Im hoping doesn't cost too much to replace..Anyone know what the price is for an actuator?
Old Jun 24, 2004
zen_master's Avatar
Majestic is your friend, buddy.
www.hondaautomotiveparts.com
Old Jun 24, 2004
What did you test and how did you test it, and what did you use to test it? I also have been told that it is hard to get the actuator out, it is better to just get the locking assembly which comes with the actuator. I just need instructions on what to test.
Old Jul 19, 2004
ak's Avatar
ak
Retired Mod
ak can only hope to improve
2002 LX Coupe... 58,000 miles.
Same problem so how do i test the actuator?
Old Jul 19, 2004
ok since I have already fixed this problem, you need to take your door panel off and see if you have power going to your actuaotor. once the door panel is off, delending on what door it it, look in the corner opposite of the speaker and you will see 2 connections, you unplug those, and that piece is your actuator. I poted a DIY in the tech forum on how to fix this problem, just search for it if you have time.
Old Jul 19, 2004
zen_master's Avatar
actually, do this..
before locking the door on the driver side....with or without the remote, press the door down.....and lock it.
anything?
Old Jul 19, 2004
ak's Avatar
ak
Retired Mod
Originally Posted by zen_master
actually, do this..
anything?
Yes, it locks both doors. Does this mean that the actuator is working?
Old Jul 19, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
My driver door did not unlock when I pressed the remote. But when I push against the door from the outside, and press the remote, it magically unlocked. 33K miles. Someone here mentioned as miles go up, the actuator will not function? It's very hard for me to believe.
Old Jul 21, 2004
ak's Avatar
ak
Retired Mod
so does anybody have any idea?
Old Jul 27, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
i took my door apart i followed the wires going to the remote lock, im just going to replace the unit (door switch) inside the door there it 2 plugin's there for that. i know one is for the power door lock anyways i priced it out 145 CND for the driver's side the passenger side is 70 CND doller's hopfully this fix's my problem ... money is an issue ill get it done sooner or later.
Old Jul 27, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
HUH???? I'd like to hear more about this one. Push down on the door how?
Sorry, my locks still work, but this souds like an interesting problem that seems to start after a certain time.
Wiring harness??????
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Poopies
Apr 20, 2017 11:36 PM
MamaBear2015
May 3, 2015 02:17 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
