1997 HX oil leak
Old Jun 14, 2004
Rich's Avatar
Rich is an unknown quantity at this point
1997 HX oil leak
My girlfriend's 97 Civic HX is using oil like crazy. For the last month on average its using at least one quart per week.
I'm baffled by this. Its only got 83K on it and is in pretty good condition. I also have taken it to two mechanics who can't figure out how its using oil. It doesn't drip any, the plugs look perfect, there isn't any in the antifreeze, and it isn't smoking at all. There is no evidence of it coming out of the pipe even at high speeds.
Any ideas? All I can think of is maybe it burned up the rings.
Old Jun 14, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Check the front oil seal. It won't leak until the car is running and driving. The front seal often leaks, and is behind the crank pulley/timing belt. If it's leaking, you will find a drop of oil on the timing belt cover. If that's dry, maybe the rings, but it would smoke blue when you step on it. I somehow doubt it's the rings. You'd see oil in the intake from the PVC valve.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
