Alternator/Charge Light Blinking
Old May 29, 2004
Kyo's Avatar
Kyo
Kyo is an unknown quantity at this point
Question Alternator/Charge Light Blinking
Hi!
My girlfriend's 2003 Civic has a blinking alternator light in the gauge cluster. Anyone knows what this means? If it was steady, I'd suspect either a bad alternator or battery, but blinking???
Tnx!
Old May 29, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Don't have my manual handy here ... did you check and see what it says in there?
Old May 30, 2004
Kyo's Avatar
Kyo
Manual talks about a steady light - which would indicate an alternator failure, but nothing about a blinking light....
Old May 30, 2004
Kyo's Avatar
Kyo
Ok, found it...
It seems that for (at least) Canadian 2003 models, the alternator light blinks when the alternator is not doing its job... I measured the voltage at the battery, and with the engine running at 3000 rpm, I still get 12.2 volts - exactly the same as at idle...
Oh well, warranty work for the dealer, with only 26k on the LX... this is deceiving!
Old May 30, 2004
Ronin's Avatar
Wait ... you're talking about the battery light, right? That's why I was kinda confused when you said "alternator" light. I couldn't find any reference to an "alternator" light in my manual. (What does it look like?)
If it's the battery light that stays on, then the battery is not being charged properly. Nothing in the manual says anything about a blinking battery light.
Old May 31, 2004
ImportRacer2123's Avatar
K20 Member
If you need an alternator I have an extra for sale.
Old May 31, 2004
Cocky's Avatar
Cocky guys kick ass!
check alternator fuse. i went through this crap for two weeks trying to figure it out, new batteries and new alternators did nothing. my speed sensor blew, and it kept blowing the alternator fuse, which made my battery die. so you might wanna unplug the speed sensor, change the fuse.. and if the battery light goes off, it's the speed sensor. just an idea..
DouglasTheGreat
May 27, 2015 11:23 PM
beveragemp
May 25, 2015 07:11 PM
Linda0818
Apr 23, 2015 11:30 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
blackbullet
Dec 1, 2001 03:44 PM
