Something is wrong with my car!!!
Old May 26, 2004
Hippiboy's Avatar
Hippiboy is an unknown quantity at this point
Question Something is wrong with my car!!!
first, i think my clutch is going bad or something... everytime i push down on my clutch it squicks(spell check??)... not a shrieking sound but it makes some noise do i need to get it lubricated or what???
second, my brake feels very spongy. i changed my own rotors and pads but did not bleed my brake line. does anyone know how???
plz help me... (specially with clutch, 2 days ago my clutch was making clicking noise when i pushed all the down)
Old May 26, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
well it could be a couple of things, for one the clutch bearing is going out and needs to be replaced, thats what i thought anyways when this happen to mine, well after spending 500 bucks and had a new clutch and bearings put in that wasnt the problem, it turns out that there was some sleaves or gearing bad inside of the tranny.
heres what you do, start the car listen for the bearing spin while in nutural...then push the clutch in and see if it stops that will tell you two things either the bearing is bad or there is some thing wrong in the trans.
When in drive and cruzing around mine use to make a noise like when you had a can stuck on the back of your bike wheel to give you that motor cross sound...brrrraaaaaa
well good news is i got it fixed, bad news is it cost me 1100 bucks since i voided my warrenty buy lowering my car, adding bigger rims and headers. this was my extened warrnty...that i payed extra for to...honda was up to fixing it but the other company said na and gave me my money back...punks...so i would take it in ASAP...
Old May 26, 2004
Hippiboy's Avatar
mine does not make any noise when driving around. it only when i push down on the clutch it makes noise like its not lubricated enough. but no noise when driving...
Old May 26, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
There is a TSB regarding this. It involves a dab of grease on the cluth pedal linkage,
Old May 31, 2004
AdamYYZ's Avatar
AdamYYZ is an unknown quantity at this point
This happened to me, but they are replacing my Clutch Master Cylinder.
Old Jun 1, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
My friend who used to work at honda told me that, that was a common problem. See if you can get it fix under warranty. I'm not sure if it covers it or not.
Old Jun 18, 2004
CivicTrip's Avatar
CivicTrip will become famous soon enoughCivicTrip will become famous soon enough
I have the creaking noise too, took it in yesterday and they are keeping it all weekend, said it was the clutch master cylinder and it needed ordered in. so i have no car for this weekend .
Old Jun 18, 2004
Mike4831's Avatar
Mike4831 is an unknown quantity at this point
if it squeaks when you push the pedal it it usually is the spring in the pedal assemble. it should be a normal problem. people have come to honda before and we basically are like nothing is wrong with the car.
but the clicking noises. i hope ur car is under warrenty.
Old Jun 20, 2004
detroittosag's Avatar
detroittosag has a little shameless behaviour in the past
how much is all that to fix?? i got the same problem.. i can here it clink, when in neutral, but when i press the clutch in it goes away.. i don't have no more warrenty, so how much is it outta pocket??
Old Jun 20, 2004
pr4life36's Avatar
pr4life36 is an unknown quantity at this point
mine also makes the squeeky noise when i press on the clutch, but everytime i take it to Honda they dont find nothing wrong with it b/c by the time i get there the noise is gone.
Old Jun 20, 2004
CivicTrip's Avatar
i got my car back, new clutch master cylinder, the creaking noise is gone, shifts smooth, feels great again, like its new.
mikemc422
Aug 9, 2018 05:41 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
GH04si
Apr 15, 2015 08:13 PM
BREADFAN
Apr 15, 2015 08:58 AM
ImmortalEX
Oct 31, 2001 10:00 PM
