Problem with angel eyes headlight
Old May 9, 2004
PICHY's Avatar
ALGARETE
i have moisture in one of the headlights...any idea how to take it out with out removing the hole ****ing thing appart..i was thinking to unplug all the lights, heat up the healight with a blow dryer...well if it happen to u b4 let me kno......please help
thanks guyz
Old May 9, 2004
Well if it's just moisture, then you can blow dry it by taking out the bulb socket. But it will probably happen again because the bulb holes aren't actually sealed. Mine fog here when it gets humid, but then it goes away. Sealing the actual headlight most likely won't help, because moisture can still get in from the bulb socket holes. So if you're really worried, maybe put some kind of sealent around the holes, but something that you could take out when the bulbs need replacing.
Old May 9, 2004
PICHY's Avatar
ALGARETE
yeah its only moisture...i just hope it goes away....plus the inside its stained up fron the water in there.....do u have the angel eyes on ur car?... i just dont want to remove all that **** to put back the oem headlights.....
Old May 9, 2004
Nah, I just have OEM cleared lights. If you're worried about the water stains, you could try something. But don't blame me if it doesn't work. You can try to spray some diluted alcohol inside from the light bulb hole and then try to dry it all out. Usually it won't leave any streaks behind. Don't use concentrated, because it might dull the plastic.
Old May 9, 2004
JayFReaZy's Avatar
yea, the moisture will eventually go away. Just take the headlights out and re-seal them again. It took me about 2 tries to finally seal it up real good, now no moisture gets in there.
Old May 9, 2004
PICHY's Avatar
ALGARETE
if it goes away then ill leave it as is ( thats what ur telling me right??? that it goes away...i c u have the same headlights as i do.....but just in case what u seal them up with????
Old May 9, 2004
JayFReaZy's Avatar
the moisture will eventually evaporate. however, when you get a car wash, it rains, or gets extremely humid outside, expect some moisture to build back up in the headlights. that used to happen to me all the time. I did a lil research and people said to seal them up with silicone. thats what I did, and it doesnt fog up any more. it took 2 tries though, to fully seal the whole headlight up, if you look closely at my headlights in person, u can see it on the sides of my housing, lol. O well, it prevents moisture from getting in there though, thats all i care about.
Old May 10, 2004
PICHY's Avatar
ALGARETE
thx jay
thx guyz u have been great help
stryder12
Jun 30, 2015 08:33 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
mugenca
Apr 16, 2015 12:15 AM
