car start trouble
Old Mar 25, 2004
akimoto's Avatar
akimoto is an unknown quantity at this point
car start trouble
hey guys i have a question:
sometimes when i start my car, it took like 5-7 sec for the motor to start but sometimes its fine. u guys think there is something wrong with my car?
Old Mar 25, 2004
Change's Avatar
Change is an unknown quantity at this point
Might want to get the battery checked out. Mine crapped out on me after a few long starts, turns out the battery had a defective cell.
Old Mar 26, 2004
akimoto's Avatar
battery? my car only have 8k miles on it.
Old Mar 26, 2004
flotsamm's Avatar
Could be the Immobilizer. It happens to alot of people including myself. Try putting the key in, turn it until the lights on the dash go off then start your engine. This allows enough time for the Immobilizer system to recognize the key(the green light will go off) and allow the fuel system to pressurize.
Old Mar 26, 2004
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
if your car only has 8k miles on it, bring it back to the dealership and have it checked out under warranty.
Old Mar 26, 2004
akimoto's Avatar
i did dude. i told them about this problem and the watering sound coming out out my motor. they told me they cant find anything wrong with it.
Old Mar 26, 2004
flotsamm's Avatar
Water sound? Are you talking about the gurgling sound coming from the passenger foot area? Thats just the heater core gurgling from air being trapped in the cooling system. Its nothing to worry about.
Old Apr 13, 2004
deltaagent111's Avatar
deltaagent111 is an unknown quantity at this point
i have an 02 vic, and it has problems starting sometimes.....i just assumed it was because of my stereo, but is this a common/known issue?
Old Apr 14, 2004
akimoto's Avatar
well, dealership cant find wth is wrong with it. they told me everything is fine, they tested everything. man they are worthless.
Old Apr 15, 2004
specificcivic's Avatar
specificcivic is an unknown quantity at this point
I've got the same problem even if I wait for the dashlights to go out. It usually happens when the tempurature outside fluctuates.
Old Apr 19, 2004
mugenman's Avatar
"mmmBAHHHH" - vtec y0
yeah i got the same problem 2, it started a lil while after i put a system in. but sometimes when i get in the car and turn the key it like chokes to turn on, but i pump the gas a lil and it works fine. i just assumed it was something i could have done to it cause the car only has a lil over 9 k
Old Apr 20, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
I just had my car over a month and a half now. I have just less than 4k on it. The first week it had trouble starting. Well, not trouble starting, but it took several seconds before it started.
I figured out, it only happens in the cold. I've had this happen only 2 times so far, and both times, it was cold outside. The CCA on our batteries suck. I think its rated at 410 CCA (Cold Cranking Amps).
I think its normal for that to happen with our cars. I'm pretty sure if you get a battery with higher CCA it, this probably would not happen.
Old Apr 20, 2004
jboy's Avatar
jboy is an unknown quantity at this point
We might not be talking about the same thing, but I have trouble (turning over 5-7 seconds before starting) an hour after a short drive in hotter weather. I asked the dealer about it, and their explainaton was that the fuel rail has to prime itself in this time (the 5-7 seconds). They said the fuel rail can get very hot after a short drive, and the gas boils and evaportates?
Tedverseti
Apr 23, 2020 01:45 PM
dragonsblood
Apr 27, 2015 12:28 PM
Blaster30
Apr 22, 2015 12:21 PM
Dorval Andre
Apr 20, 2015 05:34 PM
deus-ex
Apr 13, 2015 12:29 PM
