Advice needed
Old Mar 18, 2004
btwracing's Avatar
btwracing is an unknown quantity at this point
Advice needed
Hi Civic fans,
I am a new member (this is my first posting). I own a 2002 Civic (4 door). I'm quite happy with the car except for a few minor issues:
1. The engine sounds like a diesel, especially when I start it in the morning. For some reason, I get the feeling that the engine isn't as smooth revving/flowing as it should be. I have only done 9,000 miles in the car in 2 years, so it is rather sparingly used.
2. The first time I apply the brakes in the morning, I get a clunk sound. Mind you, this only happens the first time I hit the brakes (when I start out).
I hope someone on the boards can give me technical details as to what could be the problem (in plain English, please, lol).
Peace,
btwracing
Old Mar 18, 2004
flotsamm's Avatar
My advice would be to bring it in to Honda and have them look at it since its under warranty. If they dont find anything at least its been logged.
The rear drum brakes are self adjusting when you reversing and braking. After a few times of doing that they should be adjusted. If your getting a clunk all the time it could be the pads shifting.
Old Mar 18, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
That clunk sound (more like a "click" on mine) is the front brake pads seating themselves, when you start driving forward after reversing. It's normal.
As for your diesel sounding engine, take it to your dealer... although I have a feeling they're going to say they can't find anything wrong with it.
Make sure you're still changing your oil regularly even with that low mileage. And air the engine out at highway speeds every once in a while. All that low-speed city driving is tough on the engine.
Old Mar 18, 2004
Ronin makes some good points. Other things to try are ground wires under the hood. I even have a voltage regulator and my car idles pretty smoothly. Although, the cold weather usually results in rough idle. Once you warm up the car, it should become quieter.
Old Mar 19, 2004
chuckp's Avatar
chuckp is an unknown quantity at this point
be a PAIN to honda.. go there for any and everything your having problems with.. i got a lot of parts replaced.. make good use of ur warranty .. becasue many dont
Old Apr 13, 2004
SPEEDZONE's Avatar
SPEEDZONE is an unknown quantity at this point
I have the 2001 Ex had the same problem with the click sound when you apply brake. i know its in the front. i brung it to the dealer and told them the problem, and you all should know what they say" we can't find the problem." They told me they tighten my shocks for me and when i drove out the click was gone. Well the clicks came back after 6 months of driving. Dealers f**k them when you have warranty they can't find the problem. When you have to pay they find a whole **** load of things to fix. So anyone know how to fix the problem, i know its not the shocks, it could be brakes?
Old Apr 13, 2004
MoneyBags's Avatar
MoneyBags is an unknown quantity at this point
1. the motor has to warm-up
2.i donno
some times the car sounds better after it has warmed up a bit but if thats not the case i donno
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
cukaracha
May 16, 2015 07:36 PM
crowtoo
May 11, 2015 06:50 PM
Jigee
May 9, 2015 11:18 AM
Myredjonda
Apr 14, 2015 07:00 PM
