Side Air Vents
Old Feb 10, 2004
contradictum's Avatar
contradictum is an unknown quantity at this point
Side Air Vents
New honda 03 here.
Not sure if this is an issue, but are the side air vents supposed to continue blowing air even if I change the air mode dial to front/windshield/feet? I thouht that it was supposed to turn off in windshield/feet mode (and only ON in the front vent mode).
Thanks. (might be a dumb question).
Old Feb 10, 2004
Mr.Modify's Avatar
LMAO @ windhield /feet mode. just close the vents problem solved !!!
Old Feb 11, 2004
Da1lyDr1ver's Avatar
yeah, if you dont want air to come into the car even tho the **** is in the off position, you're gonna have to press the recirculate air button.
Old Feb 12, 2004
MMILX's Avatar
MMILX is an unknown quantity at this point
I think in the manual it says where the air blows in each mode... might want to check that...
I think that air comes out of the side vents in ALL modes...
Old Feb 12, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
This is not a problem. Even with the fan turned off, air will still blow out of the side vents just from the car moving forward. That's just the way it's designed. If you don't want it to blow, close it manually.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Blazz
May 25, 2015 10:56 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
Microbiology
Nov 9, 2001 10:10 PM
