problem with driver sided headlight
Old Feb 5, 2004
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Lightbulb problem with driver sided headlight
Ok I unhooked the driver side wire harness that connects to the main light bulb in the headlight housing, and connected a H1 projector headlight, then flipped the light switch just to see if the projector worked, and it did not because I later found out the H1 bulb had burned out, so I connected H4 bulb back the way it's supposed to be and the driver side light comes on very dim, so what could it be???, the two corner parking light work fine
Old Feb 5, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
it could be due to the bulb, check it again and ur connection,
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
ej8
Apr 13, 2015 06:36 PM
