Idiling Problem Need Help!!!tps
Old Feb 2, 2004
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
Aright so a couple months ago my had to get a new engine because it was hydrolocked and before that it was working fine and everything. (I have an S-AFC hooked up)So neways they swapped a new engine and one day i was at a light and took off normal then all of a sudden the engine just like bogged down then suddenly abruptly picked up......after getting home with this annoying *** problem i was looking under my hood and playing around, i found out that if i disconnect the TSP the car will run with out bogging down and doing that sh*t but now i have to leave it disconnected..and it idles around 1100 rps.i took it to honda and they said they cant do anything cause of my S-AFC, saying that is the problem, but i think its a faulty TSP sensor since they replaced that too along with the throttle body when the car had been hydrolocked...i checked my connections to the ECU to the S-AFC and the wire was properly hooked up so im pretty sure its the sensor.........but i want to kno how check the sensor to see if it is messed up any HELP please ive been to 2 honda delears and they are just full of SH*T they dont even kno what and AFC was.....theyre just tryin to the blame on something else so they dont have to do anything!!!
Old Feb 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
first of all, the dealer is full of ****, 2, disconnect, cut, the ground to ur afc, and hook up the tps, if it works fine, then its ur afc. if it doesnt work fine with the afc ground cut, hide the wires take out the controller and roll to the dealer, wiring into the ECU does not directly touch the sensor
Old Feb 2, 2004
ReD2k1's Avatar
yea i disconnected the AFC and everything but my car is no longer on warranty and i dont wanna go through all of disconnecting the controller and stuff....but i had taken it to another mechanic and he hooked up the diagnostic computer and played around with the codes and it said that it wasnt receiving any signal from the TPS and he called to see how much the sensor is and they said that they dont sell the sensor by itself id have to buy the whole throttle body assembly
i wanna check the actual TPS by using a voltmeter or something to see if thats the problem but i dunnno how
Old Feb 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
um u said u had a new engine put in, they warranty the new one i know
Old Feb 2, 2004
ReD2k1's Avatar
yea they do they were first ones i went to and they just blamed it on my AFC
Old Feb 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
tell them they ahve to physically prove that the afc caused the problem, do u not know about this law
Old Feb 2, 2004
C2i0v0i1C's Avatar
SuperMODrizd
and if it didnt thent he newer engine warranty should cover that
Old Feb 2, 2004
ReD2k1's Avatar
aright ill try and do that if not ill just but a new TPS it doesnt seem that expensive
Chris71087
Jun 9, 2015 11:59 PM
Flipg123
May 8, 2015 01:15 PM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
