My speedometer jumped by 25mph
Old Nov 28, 2003
AZ2K1Civic's Avatar
The 26th I took it to a car wash then drove home without looking at my speedometer. That night I head out to a party and it says Im going 70mph when Im actually with traffic and like 45mph. I noticed this while I was driving so at the next red light I stopped and the needle rested at 25mph. So, I hit up the party and when I drive home the needle is now resting at approx 22mph. The next morning I go to drive to Thanksgiving football and its now sitting at 20mph. Its slowing going back down and as of this morning its at 10mph.
Has this happened to anyone else? Could it have been something at the carwash? (it was one of those with the track that rolls the car thru)
Where is the sensor for the speedometer? and is it be easily accessible?
Thanx
Old Nov 28, 2003
Green Civic's Avatar
Damn. I never heard of that happening to anyone. If it happens again, take it to honda. Sorry, I really dont have an answer for that.
Old Nov 28, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Did you mod your cluster? Maybe the needles are sticking.
Try this:
1. Push and hold the trip/reset button.
2. Turn the lighting switch on.
3. Turn the ignition switch on.
4. Within 5 seconds, turn the lighting switch OFF, then ON and OFF again.
5. Within 5 seconds, release the trip/reset button, then push and release the button 4 times repeatedly.
This starts the Gauge cluster self diagnostics.
The beeper will sound, the lights will flash, the LCD will flash, and most importantly, the needles will sweep all the way back and forth. If they/one does NOT sweep properly, replace the cluster.
To exit diagnostics, turn off the ignition.
Hope this helps. If you don't get it the first time, try again. Timing is important here.
Good luck.
Old Nov 28, 2003
tinman's Avatar
BTW, I just went outside to actually try this.... It works! Kinda cool. All 4 needles sweep smoothly up and back down. To repeat, just push the trip/reset button again. Nice feature. Now I can pretend I'm going 140! LOL
Old Nov 28, 2003
That's sweet. You can always take it to the dealer if it's under warranty. Did you mod the cluster?
Old Dec 3, 2003
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
are you sure it worked. I tried it just to see and i did exactly what you said using the headlights as the "lightswitch" and nothing happened. I have an 03 is that why its not doing the cluster diagnostics
Old Dec 3, 2003
FALKEN's Avatar
Civicforums Junkie
Originally posted by Tinman
Try this:
interesting...i might have to try it just for kicks
Old Dec 4, 2003
Thats cool. I will try this. Is there a recomended time you need to do this? Like once a year or something?
Old Dec 4, 2003
tinman's Avatar
It works. Tried it with an RSX also. Same sequence.
Remember, you have to push and keep holding the trip button until step 5.
Works everytime. Have to do all of this within 5 seconds after turning on the ignition.
Turn on the the lights to the FIRST click, BTW. Not to headlights.
Pretty cool diagnostic.
Old Dec 19, 2003
bluesunit's Avatar
bluesunit is an unknown quantity at this point
Ahhh, that's the problem I was looking for.
I've had the same problem happen twice, except it effects both the tachometer and speedometer. The tach adds 3,000 rpm and the speedo adds about 25 mph. After I power cycle the car 3 or 4 times it goes back to normal but it is still disconcerting.
I'm assuming its just a bizzare computer thing since power cycling fixes it . . . pulling the fuse for the computer to reset has no effect.
Anyone else with this problem, or a solution, please post.
I have a 2001 EX Manual Sedan with 40k miles on it.
Old Dec 19, 2003
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
Wow, Learning something new everyday!
Old Dec 19, 2003
ragencajun's Avatar
ragencajun is an unknown quantity at this point
common problem with drive through car washes the water that shoots up mess all sorts of things up the one i use messes up the clutch its half engaged till i give her hell just reset and it sould be good
Old Dec 20, 2003
bluesunit's Avatar
Tried the diagnostic thing last night . . . worked fine. Noticed the gauge dimmer switch doesn't work either.
Old Dec 20, 2003
tinman's Avatar
Did you check the ground cables around your intake? I think there's one around there that can affect the gauges. Been a while, but I swear I read that in a thread here before. Some small ground wire somewhere back there. A bit late for this post, but it may help someone else out.
Old Jan 8, 2004
AZ2K1Civic's Avatar
Well, it eventually fixed itself and hasnt done the same thing since...still dont know what caused it
I shoulda hit the rev/speed limiter and got a pic of my dx going 142mph
Old Mar 5, 2004
Zerodhero's Avatar
Zerodhero is an unknown quantity at this point
I wish I had that little trick when I had 2k1 civic. The speedo was always locking up and it would drive me insane.
Old Jun 21, 2004
Mistro's Avatar
Mistro is an unknown quantity at this point
Hate to bring up an old topic but does it work on Canadian models too? since we have the day time running lights and all. But im guessing that dosn't have anything to do with it.Havn't got a chance to try this yet but when you mean turn the ignition on do you mean to III? or do you mean start the car?
Crazygrlinak
Oct 8, 2015 05:06 PM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
hondalx2002
18
Sep 15, 2015 10:54 PM
MamaBear2015
Sep 15, 2015 09:35 PM
