strange exhaust problem
Old Nov 2, 2003
Hey guys,
A while back, I got a thermal rear section for my ride (direct bolt-on that replaces the stock muffler). From the first day I got it installed, the car has been acting different. If I'm cruising at constant speed around 20-40mph and I press the gas a little, the rpms drop and it feels like the car bogs. I didn't think much, cause pushing the gas harder makes it downshift fine. And when accelerating slowly, the tranny seems to stop accelerating at a certain point and shift into higher gear, even though I'm still pressing the gas. Is this normal? Thanks.
Old Nov 3, 2003
Da1lyDr1ver's Avatar
you definately have too many problems. if your warrenty hasnt expired, i'd suggest you take it to the dealer.
Old Nov 3, 2003
dru106's Avatar
ThE CoRRupToR
I know!! Its an auto just like mines!
Old Nov 3, 2003
The dealer can't do much if the engine light doesn't come on. Basically the tech guy said he can drive the car around and see, but most likely they won't be able to do anything. I know the exhaust is doing something, cause I noticed it right after it was installed. I'm at the point now where I'm just gonna drive it until something really breaks.
Old Nov 10, 2003
bong's Avatar
bong is an unknown quantity at this point
Put your OEM back on and it should do the same thing. That way the dealer can't say its from your Thermal. If it does the same thing then the car should ve repaired under warranty. If it bogs like that then its prolly something with your fuel system. Installed a cat-back or axle back will not cause anything like that.
signed ex-honda mechanic.
ywgflyer
May 15, 2015 05:05 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
bo_red
Transmission
May 3, 2015 09:14 PM
mievil
Apr 28, 2015 11:02 PM
MY01HX
Nov 12, 2001 04:25 PM
