Messed up ABS line.. HELP!
Old Oct 4, 2003
sexcivic2k1's Avatar
Unhappy Messed up ABS line.. HELP!
Today I was installing my koni's (rear), and I accidentally stretched one of the ABS lines, now my ABS light goes on, and when I stomp on the brakes, it doesn't use ABS.. is there anyway I can fix this? how much will it cost? do I just need a new ABS line (the one I stretched).. thanks for all your help!
Old Oct 4, 2003
my04wrx's Avatar
my04wrx is an unknown quantity at this point
sure, then get an odb2 scanner and clear the code after the line replacement.
Old Oct 4, 2003
odb2 scanner?
Old Oct 5, 2003
my04wrx's Avatar
you know that thing you plug in under the center part of the dash, like right where your gas pedal is. reach up under the plastic and youll find a diagnostic port. plug in the odb2 scanner there and youll get readouts of all the codes that caused the CEL. then just clear them when youve replaced the line
Old Oct 5, 2003
how do i get this odb2 scanner?
Old Oct 5, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Google
There's lot's of them out there. $149 is the best I found for a decent one.
Old Oct 5, 2003
my04wrx's Avatar
f dat, why pay? go to a honda dealer and ask if you can borrow it for 5 minutes
or try an autozon they will do it free too
Old Oct 6, 2003
hmm, cant i just buy the hose that i messed up and replace it?
or if i buy the hose, and take it to honda to fix? how much do you think that'll cost?
Old Oct 6, 2003
my04wrx's Avatar
just buy the hose and replace it, then go to autozone and ask them to clear all the error codes on the ecu. should be free
Old Oct 7, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
I did the same thing...haven't fixed mine yet...Just cuz it got pulled on a little, that means you have to replace it? I was under the impression it probably just got pulled out of place somewhere...and I'd be able to just reposition it back in.
Matt
Old Oct 27, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
why don't you just try resetting your SRS light, seems to me that would do the trick.
h4ldol
Apr 24, 2017 08:16 PM
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
Dsmak
Sep 10, 2015 08:30 PM
Dave Brabant
Sep 10, 2015 06:48 PM
