Trunk popper stuck?
Old Aug 12, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
Trunk popper stuck?
I recently discovered that I can't pull the trunk/gas cap popper up at all, it literally cant be forced up at all but opens the gas cap just fine when pushed down.. I'm sure the wire for it is fine and I unlocked the buttons of course.. what could be wrong?
Old Aug 12, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
check your trunk latch to see if the cable can be pulled easily...if not the problem must be up front where the lever is
Old Aug 13, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Your problem is the lever area. You'd have to open the lever and fix the key ring. The trunk lock/unlock mechanism is screwed up. I took mine in to the dealer. It took them 45mins to fix.
Old Aug 13, 2003
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
you pulled it up too hard. when somebody smashed my window, he was trying to pop my trunk. He was yanking the **** out of it. but it was locked all he did was jam it. all you have to do is pull up on the plastic and it will all go back together. he didn't get anything because I had thta thing locked, and I caught him because my alarm went off.
Old Aug 13, 2003
Bryn's Avatar
Bryn is an unknown quantity at this point
You're pushing it down to hard when you open the gas door. If you ever have taken that panel off, you would see that that latch has one bolt attaching it to the car. if you press too hard down on it, it will rotate a little, and then the trim panel gets in the way when you try to pull it up. I have this happen everytime I take that panel off. If you stick you finger farther underneath and pivot the handle back up a bit, it will clear trim panel. just don't push so hard to open your gas door.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Skunkone
Sep 24, 2015 04:38 PM
