Rusty Bolt!!!
Old Aug 8, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Rusty Bolt!!!
Hey all,
I just got my random technology cat last night, it looks really nice... I still had 2 hours of daylight so I was gunna put it on. The damn bolts on the stock cat going back the the exhaust are so rusted, I couldnt even get the right socket to fit. It looks like a 14mm is too big and a 13mm is too small, and I know when I put my catback exhaust on, it was a standard socket size, so I think the rust caused the nut to get bigger or something?? Anyways, i sprayed the hell out of it with WD-40, tried filing the rust off, and ended up just busting up my knuckles? Any ideas, cuz i really wanna put this cat on and post some pics and a review. Let me know if anyone can help, thanks!
Old Aug 8, 2003
DUGMAN's Avatar
DUGMAN is an unknown quantity at this point
try using visegrips and a prybar for leverage
Old Aug 8, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Ok.. this is how I got it off. Spray them a couple of times with WD-40 and let it sit a few hours. Get under the car laying on your back. Put the wrench on the bolt and grab it with both hands up over your head. put your right elbow on the bend in the exhaust for leverage and pull. They pop right off.
Old Aug 8, 2003
IDQcivic's Avatar
but what wrench?? I can't even get a wrench on there that will fit, maybe the wd40 had time to work its wonders and when I try it next time it will hopefully work....
Old Aug 8, 2003
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Use a high-powered air tool with impact sockets if you have one.
Otherwise try to use a regular socket with a 1/2" drive huge breaker bar.
Old Aug 9, 2003
Jap-Euro Fusion
I did with a 3/8" drive socket wrench. If you're a whimp... I guess you're screwed... get an air wrench. To get the top one out I used a 1/4" with a 2" extension.
Old Aug 11, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
maybe some standard sized would fit
Old Aug 11, 2003
opto_isolator's Avatar
Post pics of the random tech cat - also, let us know how it works!
Old Aug 12, 2003
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
you best bet is to sand the rust off or continue using a filer until it fits in the 13mm socket again .. g'luck bro
Old Aug 13, 2003
IDQcivic's Avatar
I messed around with it all last weekend, tried everything I could and none of the bolts would budge, the threads are all rusted so I think I'm gunna have to cut the bolts off... this really sucks, because I waited like a month for the cat and now I gotta wait even longer....
Old Aug 13, 2003
ohmysac's Avatar
mine were rusted like that too...i got a socket that i could jam on there good and put it on a decent lengthed prybar...and used my foot to break that **** loose...your legs are alot stronger than your arms...
Old Aug 14, 2003
IDQcivic's Avatar
keep in mind my car is very low.... even when i get it up on jackstands, I can barely fit under it.... I gotta find a place with a lift that I can just drive on to, like when they do an oil change....
Old Aug 15, 2003
ohmysac's Avatar
try driving up on some 2x10's...and putting a block of wood on the jack's seat if u havnt done this already...just doing that gives me a whole lot more room underneath...lay down and use the ole foot and push as hard as u can...give it a good push...then pull it towards you and tighten it a bit...then push it again...that sometimes helps break stuff loose
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
amrhamed
Sep 21, 2015 02:56 PM
