2 Questions Pleez
Old Jul 25, 2003
rodney's Avatar
rodney is an unknown quantity at this point
2 Questions Pleez
does anyone know if there is a difference in the dx,lx, and ex 5 speed transmission
i have a grind sometimes only when i take 2nd up to about 4.5rpm or higher and shift to 3rd anyone else have this problem or heard anything
Old Jul 27, 2003
XtremeJM's Avatar
no difference
Old Jul 28, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Originally posted by xtremejm
no difference
There is a difference. Figure it out before you post something dumb.
LX/DX
1st Gear 3.461
2nd Gear 1.869
3rd Gear 1.241
4th Gear 0.969
5th Gear 0.71
Final Drive 4.111
EX
1st Gear 3.142
2nd Gear 1.869
3rd Gear 1.241
4th Gear 0.969
5th Gear 0.756
Final Drive 4.411
To the other question... thats a synchro going bad. There's a TSB about 2nd gear grinding and popping. Take it in.
Old Jul 28, 2003
rodney's Avatar
cool thanks man i dont understand the gear ratios though could u explain it if not i understand rodney = tranny noob
Old Jul 28, 2003
Jap-Euro Fusion
Ok... lemme take a crack at this. I know what they do, I just don't know if I can explain it real well.
Your engine always has the same rev range, idle to redline. However, that is not a large enough band to provide both low range power and high end speed. The gears magnify the rev range to give you power at low speed and the ability to operate at high speed.
I'll use EX gears for an example.
Ever tried to get your car moving in 4th? It just isn't gonna happen. The engine doesn't make the torque to move the car from a standstill. now... throw it in 1st... it goes no problem. You're basically using a gear 3.142 times larger than the "engine gear" (there really isn't such a thing). So what it does is let the engine rev faster, thus giving you the power you need to roll. Then from there, the gears get progressively shorter since the static inertia is gone. You'll notice by the time you hit 3rd or 4th, the RPMS won't climb nearly as fast as they do in 1st.... That's cuz the gears are "shorter".
Gear Ratios are different in every car, the final drive effects it too... we've got pretty tall final drives... the final drive basically helps the car to stay in some sort of "ideal range" of power... what ever that means. You'll see people messing with their final drive gear, especially on drag cars (so they don't run out of gear right before the end). Lower final drives are good for quicker acceleration, higher is good for top end. Every car is a bit different, you'll find every car has it's own shift points etc... example... my dad's 325Xi is a 5 speed, but it's basically a 4 speed with an overdrive. 5th is 1:1, but it's got a 3.8 final drive... it pulls about 3K RPM at 55 MPH in 4th. Meanwhile, my car would be rolling in 5th at about the same RPM. So every car is different.
I hope i didn't mess you up too much... I don't really know how to explain it too well.
Maybe try www.howstuffworks.com
Old Jul 28, 2003
rodney's Avatar
that was really good thanks
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
