Headlights problem!?
i remmeber a whiiiile back that people were having problems with there headlights blowing out... replacing like everything and still not working well it is still a problem with mine no 1 can figure it out.... i thought id post and see if anyone had found the problem or anything i cna check to see.... thanks for the help!
My friend had the SAME exact problem with his 02 Accord. All the aftermarket lights (even the 55w ones) blew out in less than 1 month and we're not dumbasses.....we know how to handle them. Only the stock would last a long time....
We fixed the problem last weekend. Installed CATZ 4300k HID's
You might want to upgrade your wiring harness www.autodynamics.com
I had my right headlight burn out. It was weird tho. I was pulling in my garage about to turn the car off, when from inside the car, I watched as I saw the right headlight "charge" as if it were an HID and then go out. Now I only have the Hi-Beam which has become my low beam since I wont drive ghetto style with only 1 lite and im broke.
stryder12
Jun 30, 2015 08:33 PM
intensity
May 12, 2015 10:43 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
