Electrical Post information/questions/Issues about Electric parts here.
2008 Civic dashboard problem
Old Feb 12, 2026
rhvic's Avatar
rhvic is an unknown quantity at this point
Question 2008 Civic dashboard problem
My 2008 Civic DX, 4dr, 1.8l engine, automatic, is having dashboard issues. It has about 95,000km on it.
The dash readouts keep flickering as if one was just starting the car - that is, the fuel and temp gauges go full then normal, the tach goes to zero and then normal, several warning lights come on and then off, the speedometer goes to zero and then normal, and the main odometer and trip odometers do not increase at all. This all happens while driving or parked, and the flicker happens quite consistently, every six seconds or so!
I have cleaned the battery terminals, and that seemed to help for a while, then it went back to the 'every 6 seconds' flicker.
My OBD tool gives zero codes. The car seems to drive just fine despite the dashboard flickering.
My next attempt will be to change the ignition switch. But in the meantime (until the new part arrives) does anyone have any idea what is going on, or how to fix this, should the new switch not help?
Old Feb 13, 2026
Colin42's Avatar
Re: 2008 Civic dashboard problem
More likely the connections for the dash, or a bad solder joint on one of the boards is the issue
Old Feb 18, 2026
rhvic's Avatar
Question Re: 2008 Civic dashboard problem
I ordered a new ignition switch from a provider who claimed it was suitable for my car. Alas, after installing it, I had the same dash problem, but now the radio and heater/defroster etc.control panel had no power at all! Thus, no good.
I put the old switch back in. Now the car still has an erratic dash, but the flickering period has gone from 6 seconds to about 11 seconds. It seemed to be decreasing as I continued driving. The odometers worked for a brief time (maybe 7 km) before not working again.
I do not have the personal ability to go looking for erratic solder joints.
I could try another ignition switch from a better source.
Anyone else have any insights?
Old Apr 16, 2026
rhvic's Avatar
Lightbulb Re: 2008 Civic dashboard problem
A follow-up on my post would seem to be in order.
After trying to fix the dashboard 'flicker' problem for about two months (I repeatedly tried disconnecting the battery, cleaning the terminals, trying to 'hard reset' the electronics) the problem would reduce for a few days (flicker less often, maybe every 45 seconds to begin) and then would get progressively worse again with time. At one point the dash was flickering every second! Most annoying, and also the odometers stopped advancing while this was going on. I did of course also change the appropriate fuses, but no effect.
About three weeks ago I tried a battery disconnect again. This time I took greater care to really clean the battery positive terminal, and thereafter by some miracle the dash started to work properly again. It has now run properly for over three weeks, no flicker at all, and the odometers are working as expected. Happy times again! No need for any other new parts.
So if anyone else experiences this, I suggest a good clean and polish of the battery positive terminal and connectors (as well as the cathode), to see if that sorts the issue.
Old 1 Day Ago
rhvic's Avatar
Here is the latest (and hopefully the last) post about my dashboard issue.
I got about 200km down the road (yes, that is all I drive in three weeks!) before the dashboard once again started to go bonkers. At one point the dash was turning itself off and on every 0.5 second or so! Very annoying and distracting.
I decided to try a new battery - not a bad choice since the one I had was eight years old! I'm told that the internal resistance of an old battery can be the cause of the symptoms I saw, yet I cannot fathom why the dash (low draw) had erratic problems when the starter (high draw) had no problem. Perhaps someone with the appropriate electronics knowledge can shed some light on that?
The dashboard has been just fine since the new battery, a couple of weeks ago.
So, if you have an erratic dashboard, before you pay someone exorbitant rates to diagnose the problem, consider a battery replacement for about the same money.
Depathyr
Electronics
Dec 29, 2023 08:27 PM
Rchuntr
Dec 6, 2023 07:12 PM
Johnny Rocco
Electronics
Jan 1, 2023 09:33 AM
Knixvo
Electronics
Sep 22, 2021 02:28 PM
jafish1971
Sep 30, 2014 10:02 AM
