Electrical Post information/questions/Issues about Electric parts here.
2013 Honda Civic LX-Ignition module security bolts
Old Jul 28, 2023
slogan63's Avatar
slogan63 is an unknown quantity at this point
Good evening,
Thank you for granting me access. Strange question, I have to remove my ignition module. I am down to the security bolts holding the module to the steering column. I read online that these bolts are reversed threaded in the 2013 Civics, i.e. right to loosen, left to tighten. I have tried the hammer and chisel method and the bolts don't move. Are they reverse-threaded or not?
Old Jul 31, 2023
emich's Avatar
emich is an unknown quantity at this point
Re: 2013 Honda Civic LX-Ignition module security bolts
They are reverse threaded and with flat heads, but you don't need to remove the module in order to take out the ignition switch which is held by 2 small screws only. One front up and the other down back. Use 90 degree short screwdriver or hold with pliers P2 Philips bit. It's a tight space but it's doable.
LilHonda
Suspension
Aug 10, 2022 07:11 AM
Gobi
General 8th & 9th Gen
Jul 6, 2022 11:07 PM
sujith6789
Bluetooth
Jul 12, 2021 02:28 AM
mbrittb00
Exterior
Dec 28, 2019 12:32 PM
2013CivicDriver
Jun 7, 2013 06:38 AM
