Electrical Post information/questions/Issues about Electric parts here.
Alternator Voltage issue
Old Feb 19, 2022
rkravetz's Avatar
rkravetz is an unknown quantity at this point
Hi,
I have Honda Civic Hatchback 2013 9th gen 1.8L
95K km
Measuring the voltage at the battery/alternator while the engine is running shows me approx. 12.5V (checked it with two different voltmeters)
I don't have any light indicators or any other issues, my battery is almost 2 years old.
Is it normal or is there a problem with it?
Other than replacing the voltage regular is it possible that there is a problem with a different part?
Thank you for your help.
Roman.
Old Feb 19, 2022
FRSam's Avatar
Click Here
Re: Alternator Voltage issue
With the engine running, it should show ~14.3 volts. This means the car is most likely running off the battery and the alternator is failing/has failed.
Old Feb 19, 2022
Colin42's Avatar
Could be the computer doing that to increase fuel mileage, the older cars did that.
try turning the lights, fan, AC on and see if the voltage jumps up
Old Feb 25, 2022
rkravetz's Avatar
Thank you for your comment.
Thank you sir, you saved me some headache and a lot of money.
ArdyC
Electrical
Jan 27, 2022 01:04 AM
BCiv03
Oct 22, 2017 08:13 AM
Bricoleur
Sep 9, 2015 12:23 PM
airognol
Mar 25, 2013 09:55 AM
Tylerleefalter
Feb 21, 2013 11:45 PM
