Dropping voltage when pressing the brake or at a stop
Once the car is waiting at a redlight i have my turbo timer on the volt settings and i see it drop from 13.5V to 12.1V
If i put the car in park, while still stopped the volts will jump up then once in drive it'll drop. I also notice lower levels while coasting, but once I accelerate a little bit itll jump back up.
couple things to note,
1. I need to clean the battery connection cables, little bit of battery corrosion on it from the old battery.
2. Cheaper-side aftermarket alternator, destroyed my OEM alt with a sound system (no longer connected)
3. the ground and power cables are looking a bit old, going from the alternator. maybe have to replace soon or in future
4. Battery is new when i got the alternator.
not sure what is drawing so much power when it's stopped or while its coasting, I would maybe say the aftermarket injectors or something but those aren't even going when stopped.
re: Dropping voltage when pressing the brake or at a stop
Re: Dropping voltage when pressing the brake or at a stop
lots of people that installs oil pressure gauges freaks out when they see the low pressures at idle (which is absolutely normal)
Steve General
General DIY
Apr 25, 2017 02:21 PM
vietstylez
38
Jun 6, 2014 11:12 AM
skerbz
Oct 26, 2012 12:28 AM
aznsmtboy
Sep 18, 2002 11:59 AM
Vinas
Jun 27, 2002 10:05 PM
