Turn Signal Relay
Turn Signal Relay
Hi all,
I have a 2009 Civic Sedan EX-L when the left turn signal is on both front and rear bulbs flash rapidly. When I press the hazard button all four bulbs flash normally. Research says that the turn signal/hazard relay may need to be replaced. I looked through the owner's manual and it has no information on the turn signal relay. I found a youtube video of someone with a7th gen replacing theirs under the dash, but the 8th gen looks completely different and I don't see where the relay is under the dash.
Does anyone know where the flash signal relay is located and is it the same part number for the7th gen?
TIA
TIA
Re: Turn Signal Relay
Not sure if it's a separate relay for 8th gen, might be integrated into something else. Are you able to find a replacement relay online for 8th gens?
Single73
Dec 2, 2012 08:02 AM
Colombian4Lyf
Oct 24, 2006 10:54 PM
boosting
Sep 11, 2006 11:30 AM
