Electrical Post information/questions/Issues about Electric parts here.
Inj and ign relays no ground pulse when starting ??
Old Apr 22, 2020
Davepnola's Avatar
Davepnola is an unknown quantity at this point
2007 civic lx ... no ground signal to the pgfi relay and ignition coil relay .. under the hood
Can someone tell me what sends the ground pulse to these relays ? IGN switch ? Or Ecu ?
Wiring diagram would help thanks in advance
Old Apr 23, 2020
BrotatoChip's Avatar
Super Moderator
Re: Inj and ign relays no ground pulse when starting ??
The ECU provides ground for the injector and PGM relays.
Service manual can be found here: http://civic.hondafitjazz.com/manual2.html
Old Apr 23, 2020
Davepnola's Avatar
Yeah I kinda gathered that ..,, can u reflash a used pcm ? Thanks
Old Apr 23, 2020
Davepnola's Avatar
Who’s the best at rebuilding , I called 2 rebuilders told them stars going on with the pcm and they acted clueless ... thanks or do I buy a used good one and get it reflashed ?
Old Apr 23, 2020
chuffsy's Avatar
chuffsy is an unknown quantity at this point
Thank you for that link
Old Apr 24, 2020
Super Moderator
It would probably be cheaper to just find a used PCM. Put it in the car and bring it to a dealer to reflash.
Old Apr 24, 2020
Davepnola's Avatar
I saw the video on YouTube on the guy pulling the 2 chips off the board and resoldering them ... in I might go that route ...
Old Apr 25, 2020
chuffsy's Avatar
With the grounding issue , how does the car drive? Is it something that you saw or maybe a code from a check engine light?
KillerCam251
Aug 9, 2017 09:01 PM
anotherD3MISE
22
Jun 29, 2017 05:44 AM
jackoncruzpr
Sep 4, 2016 07:42 PM
beasley2013
Apr 5, 2014 01:05 PM
td1238
Mar 9, 2012 12:12 PM
