Right rear turn signal Out - confirmed its not the bulb or plastic socket
The thought is I inadvertently pulled a wire out off a contact inside the wiring connector that plugs into the signal socket. Running, brake and reverse are still operating. Thoughts on if a fix like this doable? The whole wiring harness is probably going to be a lot more time and money than I'd like to spend.
Any comments or guidance would be greatly helpful.
Thanks
Thanks
Re: Right rear turn signal Out - confirmed its not the bulb or plastic socket
You can buy a new connector/socket that you can splice on. Either solder and heat shrink, or good crimp connectors.
Anticrosswalk
Jul 21, 2015 01:37 PM
lgs 98dx
Jan 12, 2013 10:34 PM
abmerop18
Jul 27, 2003 08:23 PM
