Electrical Post information/questions/Issues about Electric parts here.
Window Switch
Old Sep 4, 2019
chrp's Avatar
chrp is an unknown quantity at this point
Radio Display
Honda Civic 5dr 2010
Radio display does not properly work. Details are not shown clearly. How to fix it?
Thanks in advance.
Old Sep 4, 2019
chrp's Avatar
Speedometer
After a battery installation, my speedometer does not properly work. Specificaly, speed displayed is not the correct one.
How to fix it?
Thanks in advance.
Old Sep 4, 2019
chrp's Avatar
Radio Display
Thanks in advance.
Old Sep 4, 2019
chrp's Avatar
Window Switch
Honda Civic 2010 5dr
After a battery installation, I cannot open co-driver's window, from my door (driver's switches). Why this happens and how to fix it?
Thank you.
Old Sep 4, 2019
Re: Window Switch
All threads seem to stem from same issue.
Merged them all together in one thread and moved them to the correct section of the forums - all were in wrong portions of the forums.
Old Sep 4, 2019
Colin42's Avatar
Re: Window Switch
Try disconnecting the battery, wait 20 mins and reconnect. Make sure your connections are clean and tight
Old Sep 5, 2019
chrp's Avatar
Re: Window Switch
Sorry for that. Just registered, so I didn't know under what forum I had to put the threats. I received a message that all have been moved to the correct section.
Old Sep 5, 2019
chrp's Avatar
Re: Window Switch
Thank you for the information. I will try and revert if it works or not.
kathy27
Mar 13, 2011 07:39 AM
albertcivic
Oct 8, 2010 10:19 PM
nyce1
Sep 23, 2010 03:02 PM
trev0006
Sep 30, 2009 02:01 PM
