Brakes Post information/questions/Issues about Brakes here.
Front disk brake guide pins location [solved]
Old Apr 22, 2023
digger's Avatar
digger is an unknown quantity at this point
This is a 2009 stock 4 door Sedan 1.8L car. I think the last time the front rotors and ceramic pads were don they may have switched the "guide pins". pin A for Pin B. When they were lubed up. One pin has flat sides and is very specific as to location. QUESTION: Flat sided guide pin goes top or bottom?? I see mixed guidance
Old Apr 22, 2023
Colin42's Avatar
re: Front disk brake guide pins location [solved]
Go to a site like honda parts now and look at the diagram
Old Apr 22, 2023
digger's Avatar
Thank you, haven't been there yet.
Old Apr 22, 2023
https://www.civicforums.com/forums/2...retailers.html
not an upgrade, rather an mechanical issue, moving to proper forums section
Old Apr 22, 2023
digger's Avatar
COlin42, using your suggestion I went to(Honda parts now) plugged in my Vin and got the answer. WIth this particular Vin the Guide pin with the flat sides goes on the bottom, called pin A. Pin B as they call it goes in the top. PIn also has a grove. Very important to get them in the correct location.
bugbitten
Sep 3, 2021 07:04 PM
Goletadude
Wheels and Tires
Jul 25, 2010 11:03 PM
def01tones
Jun 22, 2005 06:49 PM
civicex2002
Aug 8, 2003 07:52 PM
