Brake Caliper Piston Won't Retract
Rep Power: 0 Brake Caliper Piston Won't Retract
I have an 07 Honda Civic DX and I am replacing my front brakes at the moment. Last night, I replaced the old brakes and put in new ones but then I noticed the brake caliper was in the way. So, I tried to retract it with a C-Clamp and that didn't work, I tried bleeding the brakes by removing the nipple and that didn't work, so I pumped the brake, while the car was on and E-brake off, and noticed that the rubber sleeve was full and tight of brake fluid. I slightly lifted the sleeve and brake fluid sprayed everywhere. Is that the reason why the caliper will not retract? If anyone knows how to easily retract the caliper can you please give me some advice? I would greatly appreciate it!
P.S. Called Honda Dealer and they said they can't help me out over the phone. That I have to tow it in and pay $150 for a diagnosis.
Super Moderator
Received 1,895 Likes
Rep Power: 197 Re: Brake Caliper Piston Won't Retract
Not a site concern, moving to correct section.
If you can't get the piston to go back in using a C clamp then it has seized and needs replaced. The rubber boot around the piston should not have brake fluid under it, it is just to keep out contaminants.
Rep Power: 0 Re: Brake Caliper Piston Won't Retract
Thanks BrotatoChip. What parts do I need to replace?
Super Moderator
The caliper.
So I didn't have to replace it. I left it alone, went to sleep and woke up (about 10 hours later) and the caliper retracted as if nothing happened. Maybe the brake fluid built up and needed time to escape on its own. There has to be a quicker way. Anyways, if anyone runs into this problem just try letting it sit for a couple of hours. I was pretty dang sure it seized but apparently it wasn't. Thanks for the help.
You shouldn't have pumped the pedal until the brakes were reassembled.
Watch out for possible complications in the future such as continued fluid leakage or maybe a dragging brake
