Help with replacement parts ordering
Old Aug 10, 2023
mustang rich's Avatar
From: I reside in South Douglas county oregon.ask someone they will know where to find me
mustang rich is an unknown quantity at this point
Hello friends. I'm in a situation and turning to all of u with better knowledge .bought daughter 07 civic si ,K20,6sp coupe last summer.was hit directly at driver's front wheel and door.looks like the hub and a arms took the blunt of damage.i need new a arms,tie rod,hub,and strut. When ordering parts,which standard civic and si parts interchange ? I'm just not familiar with interchangeability and hoping some of u will have the heart to give me the knowledge needed to properly repair her car back to factory spec.i thank those who respond with all my heart in advance for your time and effort .thank you soo much
Old Aug 10, 2023
Re: Help with replacement parts ordering
go to an online honda parts store
https://www.civicforums.com/forums/2...retailers.html
if the part number is the same, they would fit.
Old Aug 11, 2023
BrotatoChip's Avatar
Super Moderator
Sites like Rockauto are usually very good at specifying which trim the parts will work on.
Control arms: They have different part numbers but may still be interchangeable. All bolts are the same sized and even the ball joints are identical.
Tie rods: Have the same part number.
Hub: Specific to Si. Different sized axle/axle nut.
Strut: Specific to Si, probably only the spring/damping rates are specific.
jeffeff
General
Jul 13, 2019 04:48 AM
Gypsy
Nov 23, 2009 04:16 PM
wsccd3
Apr 8, 2007 07:28 PM
Jonauto
Mar 15, 2004 07:58 PM
