Replace Struts - need alignment? [solved]
Old Mar 30, 2023
jorsch's Avatar
jorsch is an unknown quantity at this point
When replacing the front struts, does the alignment need to be re-done because of the change to the suspension components?
Old Mar 30, 2023
Re: Replace Struts - need alignment?
struts, yes
double wishbone, maybe.
hondas changed to struts at 7th gen, so your case, yes
they are called "struts" because they are structural. So, alignment changes when you remove and install. Geometry changes
Old Mar 30, 2023
Colin42's Avatar
Re: Replace Struts - need alignment? [solved]
It should be done
GoBruin02
31
Feb 13, 2008 10:24 PM
Silver02EX
May 11, 2005 01:53 AM
EnProceso
17
Oct 23, 2004 06:29 PM
sKwiD
Jul 4, 2002 11:27 AM
