has anyone done an alignment lately? or still has there alignment results/values?
i was wondering what is considered a good alignment... i've got the numbers and compared it to the previous alignment that i've had. and they similar... but this time.. most have negative numbers.
additional note: on the results page, the vehicle info stated that 195/60r15 tires, not sure if that would affect the alignment since i have 205/50/16 on.....
this is what i have from my alignment:
note:
* = degree
brackets () are negative numbers
vehicle alignment report
left front
-----------------(min--spec--max)--------before------after
caster: --------------- 0.55*:2.55* -------------- 1.6* -------------- 1.6*
camber: ----------- (0.75*):0.75* ------------- (0.47*) --------- (0.43*)
toe: -------------- (0.12*):0.12* --------------- 1.76* ------------- 0.01*
left rear
camber: ------------ (1.5*):0.00* ------------- (0.61*) ----------- (0.70*)
toe: ----------------- 0.04*:0.16* ------------- 0.05* ----------- 0.08*
right front
caster: -------------- 0.55*:2.55* ------------ 1.62* ----------- 1.62*
camber: ------------- (0.75*):0.75* ------------ (0.90*) ----------- (0.92*)
toe: ----------------- (0.12*):0.12* ------------ 0.49* ----------- 0.01*
right rear
camber: ------------- (1.5*):0.00* ------------ (0.74*) ----------- (0.80*)
toe: ----------------- 0.04*:0.16* ----------- (0.10*) ----------- 0.08*
alignment values
------------------ front ------------------- rear
total toe: -------------- 0.02* ------------------ 0.16*
set back: ------------- (0.11*) ----------------- (0.03*)
track width diff.: ------------------- (0.40*)
wheel base diff.: ------------------- (0.08*)
thrust angle: ------------------------------------- 0.00*
camber difference: ------ 0.49* ------------------ 0.10*
casteer difference: ----- (0.02*) ----------------- ---
if anybody have any experience or knowledge with alignments, please share.
thanks.
note:
* = degree
left front
left rear
right front
right rear
alignment values
thanks.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
TheRiddicles
Sep 21, 2015 01:28 AM
