2012 Can't move from Park to Drive/Reverse (Intermittent)
Old Sep 27, 2023
Eeshen's Avatar
Eeshen is an unknown quantity at this point
Hello
Sometimes my Civic won't allow me to switch from Park to Drive/Reverse (automatic transmission) and vice versa. The "thumb" button won't push in. After a while, it will work again. It also appears if I rev the engine a bit, it helps.....but maybe just lucky.
Any thoughts as to why this is happening? My fear is I will be stuck one day unable to change the transmission.
Thanks,
Old Sep 27, 2023
Colin42's Avatar
Re: 2012 Can't move from Park to Drive/Reverse (Intermittent)
There should be a little override thing hidden on the shifter console to take the car out of park without needing the key. Check the owners manual. Either the button is sticky, or maybe its not always getting a good signal from the brake switch, or the little solenoid is getting sticky.
Rod Franklin
Detailing
Oct 11, 2025 08:28 AM
hondciv
Bolt-on Engine Performance
Jun 2, 2023 01:35 PM
maxmccoy1969
Feb 16, 2016 07:23 PM
bountybuddy
Nov 3, 2014 05:00 PM
WICKEDPHOTO
North East
Mar 11, 2012 11:59 PM
