2014 civic broken cvt belt
I have a 2014 civic with 143000klms in which I I bought the Honda plus warranty of 120000klms, so it's out of warranty and my CVT belt just broke apart!! Has anyany else heard of this happening?? Contacted honda of Canada to try and get help, I also work for honda manufacturing and because I never got a transtransmi flush done Which I have told them never even came up for service till 140000kKlms they will not help me!! They basically told me that I was lieing there is No way the tranny service never came up it should have came up at between 80-90000 Klms so because I didn't follow the warranty service excactly they will not help me. Has anyone ever had there number 3 service come up later then what they are telling me it should have? Took the car to a Honda dealership they got me to change a few sensors which did nothing! Spent $700 a the dealership trying to get the car fixed just to finally take it to a transmission shop for them to finally find the problem, know I'm looking at $2500 to have the transmission fixed.
Re: 2014 civic broken cvt belt
Check the print in your owners manual, If it lists 90,000km you're out of luck. If it lists 140,000 like you said you're closer to getting it fixed under warranty, but you are still overdue by 3,000km.
Our 2015 Civic, without warning, lost all transmission about 10 days ago. The shop said they pulled trouble code P1890. They found that CVT had failed and needs replacement. We've had the car 2.5 years - high mileage though , ~120K.
We called Honda and argued that even though the car is out of warranty due to mileage, we should not have to foot the entire $5K bill. We've maintained the vehicle per the service schedule, and have nothing to it to merit catastrophic transmission failure. they opened a case file, and within 2 days returned are call, agreeing to pay 80% of the repairs.
Picking it up today, if they complete the job. I will be interested to know if the CVT belt broke or something else within the transmission. I've heard even a small l amount of slippage is all it takes to ruin a CVT.
We put on more miles than the average driver. Could we be a canary in the coal mine? I predict we see more and more of these as others exceed the 100K mark.
Note - this is my first post. signed up to reply to OP. Apologies if this is old news, but do you know about the 2015 recall? Fit and Civic CVTs? https://blog.caranddriver.com/honda-...r-cvt-trouble/
Nobody at the dealership is going to open up the trans to find out for sure though, they just replace the transmission.
Before removing the trans, when they drain the fluid out, IF some solid chunks come tumbling out of the drain hole, that might give a clue as to what happened
Yes it was - and Im not taking it for granted. They could easily have turned down the claim entirely, and I've no recourse other than a second job til I had the money to pay. Kudos to Honda. Also - helps me make up my mind re my next car (prob a Fit (with Manual)). We were also told that if a recall is ever issued, we will be reimbursed our portion of the CVT they just put in.
You are correct - just picked it up - and they did not crack it open, in fact they completely stonewalled when I asked about it. The clerk seemed very nervous and defensive, even though I was nothing but grateful that they agreed to split the cost. It was kinda strange really. Wonder if they are starting to see CVT failures with increasing frequency.
(And $%#^, meant to write "returned our call" not "returned are call". My first post, and aleady with the typos)
btw - wanted to add, the trouble code that was pulled was: P1890. Like ezone said, the only diagnostics they did was to pull that code, which, according to the shop, means tranny is dead an must be replaced. Like ezone said, they did not crack it open or look at it in any way.
To oversimplify it: Erase the code. Drive the car. Does it set the code again? Replace the transmission.
The old unit is boxed and returned to the manufacturer.
People can scream loud when something expensive fails though.
My 2014 Civic with 140k miles and trans just went out with same issue. Chunks of metal coming out of the bottom drain hole. Honda is basically telling me I am screwed. Sounds like there is a known issue with the trans on this car. I am hesitant to fix it with another flawed CVT trans. This is very frustrating.
Hello alphabet25,
I'm trying to get this information out to as many 2014-2015 Civic owners with failed transmissions as possible.
I too have a catastrophic transmission failure on my 2015 Civic EX with 85,000 miles. Honda has refused to help.
Please report your problem to the only organization that can do anything about it - the National Highway Traffic Safety Administration aka NHTSA (****. knit-sah) which is part of the Department of Transportation (DOT). At least 40 other Civic owners have done so. Honda recalled 2014-15 Civics in October 2015 to effect a change to the computer software to prevent this failure. By my calculation there may be as many as 18,000 vehicles that were not included in the recall, but evidence is mounting that they should have been. Even though your car is now fixed, please help the rest of us that are facing bills of $5000-$6000. You will be reimbursed for the 20% you did spend if the recall is broadened to include the 18,000. Thanks!
they actually require more servicing than regular autos... like 30k mile fluid change
The issue is that when they fail, it's a whole replacement. No rebuilds.
Googling should show that Hondas are not the worst.
one of the results from googling
https://carfromjapan.com/article/car...missions-last/
Hello...I'm a little late to the party, but I felt my story is worth sharing. I bought a used 2015 Honda Civic from Mercedes Benz of Stevens Creek in September of last year. The mileage on the vehicle was 55,588 at time of purchase. I signed the documents on Sept 11, and took delivery of the vehicle on Sept 14. During the purchase process, I was given a copy of a certified checklist of everything that was supposedly checked out on the car. On the checklist, it says that the transmission fluid level and condition was checked and met the standard.
Well...on the afternoon of Monday Oct 2, 2023, the transmission suffered a catastrophic failure. I had it towed to Honda of Oakland the next morning. When the Honda mechanic got the car, the first thing they did was check the transmission fluid levels. They said it was really low, but found no leaks or signs of leaks. They drained what was left, and refilled it, drained it again through a strainer and found all these chunks of metal. They said the transmission needs to be replaced, and quoted me $9707 for the service. The car currently has 80,000 miles on it.
So something doesn't make sense, here. This car has a CVT transmission and as I'm sure your mechanics know, maintaining proper fluid levels and condition is critical on these gearboxes. How does a car with only 80,000 miles on it blow a transmission unless it wasn't properly maintained? I have a feeling that the dealership misrepresented the inspection checklist.
And what makes it so bad is that I'm still making payments on this car.
I'm at a loss on how to proceed.
CDelaney94
Feb 24, 2015 05:29 PM
Readypro
Jul 22, 2014 06:54 PM
Volti
Jul 19, 2014 08:36 PM
danwat12345
Feb 2, 2014 08:43 AM
ridethelighting
Nov 10, 2011 12:09 PM
