Shift lag
Old May 2, 2021
SpaceXPiston's Avatar
SpaceXPiston is an unknown quantity at this point
Shift lag
My 01 civic lx that I recently got has a few weird transmission issues. It used to have a long delay between shifting gears (its automatic) but was greatly reduced after changing speed sensors. It still does it badly while turning and the gear shift can slide from drive to neutral just by a light touch, even with the shift **** off. It has the codes p1705 and p0600
also the temp gauge doesn't work, and the speedo is double what it should be
Old May 3, 2021
BrotatoChip's Avatar
Super Moderator
Re: Shift lag
You have a range switch issue, a serial communication issue, and a VSS issue. All of these could have an affect on the way the transmission shifts. These need to be fixed.
Transmission failure in the '01 is also common so be prepared for that.
Rambo2
Apr 22, 2008 04:20 PM
HyaBoosta
70
Dec 3, 2004 06:11 PM
civichxtreme
Jul 7, 2004 03:59 PM
odie
Apr 26, 2002 04:22 PM
