New clutch is slipping
Old Jul 11, 2020
Shanvhere's Avatar
Shanvhere is an unknown quantity at this point
I have a 06 Civic Ex, put a new clutch 3,000 miles ago and now when I give it some good torque the clutch begins to slip but doesn’t have that clutch smell, I did the normal clutch break in but is this normal?
Old Jul 13, 2020
BrotatoChip's Avatar
Super Moderator
Re: New clutch is slipping
No. A new clutch should never slip when the pedal is completely released. A few things to check:
-Oil/fluid leaking on the flywheel/clutch?
-Was the flywheel replaced or resurfaced?
-Does the clutch feel normal? Grabbing at the same point off the floor as the previous?
-Is the clutch pedal releasing all the way?
-I'm not sure if 8th gens do but some Civics have a clutch adjustment nut on the master cylinder/clutch pedal. Maybe try adjusting it.
Old Jul 13, 2020
Shanvhere's Avatar
I was thinking oil may be seeping in there some how but I’ll do some investigating, if there is oil residue I just drive it normally until it dissipates?
Old Jul 13, 2020
GolNat's Avatar
Prelude Owner
Is there oil residue where the trans bell housing meets the motor?
Do you feel anything through the pedal when it is pressed in?
CEL on? We had another member a week ago think his clutch was slipping but it was actually a bad sensor causing the engine to bog down.
Old Jul 13, 2020
Shanvhere's Avatar
There is oil on the housing but don’t know what’s leaking cause it doesn’t indicate where, there is a leak but I’ll have to investigate it. I didn’t think it would interfere it.
Elatria
Mar 21, 2016 08:44 AM
manthatguysfast
Dec 25, 2007 07:18 PM
Ashhole
Mar 17, 2006 11:46 PM
nerdyb
18
May 28, 2002 10:27 PM
supsoop
May 5, 2002 12:32 AM
