clutch change Torque spec.s
Old Dec 25, 2018
Aerose91's Avatar
Aerose91 is an unknown quantity at this point
Im replacing the clutch on my '06 EX with the 1.8l engine (R18 i believe?) and don't have a manual so I'm wondering if anyone has the torque spec.s for:
-Flywheel (87 i think?) I haven't done a clutch in years, are there timing marks on the flywheel? I'm putting a new one on
-Pressure plate (19 i think?)
-Tranny mount bolts to engine
-2 motor mounts, one from tranny to frame, other engine to sub frame
-The 4 long-*** sub-frame bolts in the corners that took me an entire day to get out because they were so siezed
Also, is the crank bolt on our cars torque to yield?
Thanks for any help guys & gals!
Old Dec 27, 2018
mightymouse0325's Avatar
mightymouse0325 is an unknown quantity at this point
Re: Torque spec.s
The crank bolt I believe is somewhere between 34-40 ft lbs, then rotate it an additional 90 degrees, don’t quote me on that I could be wrong. I don’t remember the last one I replaced being torque to yield, but I do know that I have broken a few in the past. Most times you can call a local Honda dealer and they can tell you the torque specs
Old Dec 28, 2018
Re: Torque spec.s
Why TF not? Got a library card?
'06 1.8l engine (R18 i believe?)
-Flywheel 76 ft-lb
-Pressure plate 19
-Tranny mount bolts to engine 47
-The 4 long-*** sub-frame bolts 76
yes 51, +90 degrees
Old Dec 28, 2018
Aerose91's Avatar
Re: Torque spec.s
Cuz i wasn't planning on buying this car so i didn't grab a manual for it.... yet
Thanks man! That really helps
Old Dec 30, 2018
Aerose91's Avatar
Re: Torque spec.s
Got the tranny off today and the release fork was shattered. No wonder the clutch wouldn't disengage!
HondaLuv3r4Life
Jul 31, 2017 05:47 PM
bobsagator
18
Jan 22, 2013 06:45 PM
civcspool
Mar 5, 2008 01:37 AM
usafstud
Engine Swaps
Feb 6, 2006 02:22 PM
