Automatic Transmission Oil Pressure Switch
Old 11-27-2018
joenobodyyet's Avatar
joenobodyyet is an unknown quantity at this point
My car (2008 Civic LX automatic 4 door, 75,000 miles) starting shifting weird a few weeks ago and the green light next do D(drive) started flashing, then my check engine light came on. I got codes P0847 and P0756. After about a week, the check engine light went off, and it seems to be shifting better again. I have read MANY posts online about this common problem and most say that it's most likely a bad transmission pressure switch sensor. I figured I would buy one and swap it out, but I am not sure exactly which transmission fluid pressure switch to get. Here are the 3 options I have seen in posts:
28600-RPC-013
28600-RPC-003
28600-RPC-004
I was sent this: "The 3rd Clutch Transmission Fluid Pressure Switch is Honda part # 28600-RPC-013 which replaced part # 28600-RPC-003.
The washer/gasket part # is 90471-PW7-A00. The switch is located at the bottom of the transmission housing."
So I went on eBay and bought a genuine Honda switch part 28600-RPC-013, but the person sent me 28600-RPC-004. I was under the impression that the -004 was for the 2nd gear/clutch transmission fluid pressure switch and the -013 (which replaced -003) was the 3rd gear/clutch transmission fluid pressure switch.
The guy on eBay says that the 28600-RPC-004 is the replacement part for 28600-RPC-013. Can anyone help and confirm if this is true or not? I would rather not take a gamble with the wrong part. Thanks
Old 11-27-2018
Re: Automatic Transmission Oil Pressure Switch
https://www.civicforums.com/forums/1...ml#post4754364
Old 11-27-2018
I wonder if we have any other opinions in this forum? Anyone have any knowledge on these parts?
Old 11-27-2018
Look in the parts catalog that was already linked for you to look at:
28600-RPC-004 is 2nd gear pressure switch.
28600-RPC-013 is 3rd gear pressure switch.
Can they interchange? Maybe. Probably.
If you don't like what you already purchased, order the correct part number from your local dealership.
Old 11-28-2018
Colin42's Avatar
Received 1,132 Likes on 946 Posts
Listen to the actual Honda mechanic, how's that for an opinion?
Old 11-28-2018
Thanks guys, I checked the link sent by ezone and it was for a 2010, but I assume that it's the same parts for a 2008. I couldn't find where it says which is the 2nd gear and which is the 3rd gear. It lists them both as "switch assembly". I did notice on the diagram that one is on the bottom front and the other seems to be on the top rear of the transmission.
I just got off the phone with the dealership and the guy said that 28600-RPC-003 was replaced by 28600-RPC-013, and THEN that was replaced by 28600-RPC-004. I asked about the difference between the 2nd and 3rd gear switches and he said, "both switches are the same."
Old 11-28-2018
I was probably already looking for something in that year, or was reading another post for a 2010. At any rate, the two years use the same parts. You could just start at the beginning on the parts catalog link and build your own car to verify.
Correct, the catalog does NOT identify either item by function...that's the point where I would need to pick out which item I need, and I may refer to the factory wiring diagrams or other service info in order to correctly identify which switch in the parts diagram is associated with which transmission function.
Confirmed as per the parts catalog.
I cannot confirm this from the parts catalog. That number is shown as the 2nd gear pressure switch, as you saw in the catalog. (On that note, I'm a tech not a parts department person)
I bet they only ever stock the one switch # just to simplify their inventory.
I can't tell you they are the same, but as I said before: Functionally they are likely the same
joenobodyyet
11-24-2018 10:15 AM
sierrawindy
Transmission
02-24-2018 05:31 PM
Enriquepd
10-07-2015 05:43 PM
kingholdem87
08-26-2014 08:19 AM
walshkr
07-01-2014 05:33 PM
Quick Reply: Automatic Transmission Oil Pressure Switch
