oil leak passenger side
Old Mar 9, 2025
ngm's Avatar
ngm
ngm is an unknown quantity at this point
Any write ups on changing this rocker arm oil control valve? 2012 Civic Si Sedan MT 145K miles. Photo taken looking up into engine compartment. Cheers
Oil leak
Oil leak
Old Mar 11, 2025
Colin42's Avatar
Re: oil leak passenger side
Don't change the valve, change the gaskets, get the gaskets from the dealer. Its only 2 bolts
Old Mar 15, 2025
ngm's Avatar
ngm
Update: 2012 Civic Si not 2 bolts. 3 x 10 mm short bolts hold a separate sensor wiring mounting bracket attached to the oil valve control unit and 4 x 10 mm long hold the actual control unit onto the head. After taking off the under cowl panel there’s rather limited access to the bolts holding the units. The leak seems to be coming from the lower bolt on the pass side. Got a replacement gasket from Honda and will replace it tmrw. Hoping the valve separates from the head easily. Would be easier if I could unclip the sensor harness from the bracket but I can’t figure out how these two clips slide off. Cheers
Before test drive
Before test drive
After test drive
After test drive
How to remove these clips on the oil sensor and the wire harness hold down
Before test drive
Before test drive
Before test drive clean bolt
After test drive showing some oil
Old Mar 17, 2025
ngm's Avatar
ngm
Update #2 Swapped seal for new Honda part. Still leaks.. gonna walk on the wild side and try torquing to 25ft lbs instead of the spec 20ft lbs. Hope the bolts don’t snap. As a backup will get a dealer quote to freak me out. Here are a few pics. Cheers
Still leaks at these points. Why would there be oil in the chamber between the arrows. The chamber is outside the seal so it seems there should be no oil in there.
The head showing leak points.
Old Mar 19, 2025
Colin42's Avatar
Make sure the mating surfaces are absolutely smooth, try to torque it as evenly as possible.
qwemx
Jul 18, 2023 06:27 AM
amodedude1
Aug 25, 2019 03:39 PM
excel9976
May 14, 2018 09:49 PM
dmecivic
Dec 9, 2008 02:45 AM
dmecivic
Buy, Sell, & Trade - Archive
Nov 20, 2008 02:30 PM
