Lower block oil leak: help [solved]
Old Nov 17, 2024
Nicocenta's Avatar
Nicocenta is an unknown quantity at this point
I will attach a photo of where I have a bad leak. When you start the car it starts to stream down until empty. I replace the oil pressure sensor and cleaned that up as it was backed out and leaking down to the same area helping idea the actual cause. 1.8L lx Civic 13' thank you in advance.
Old 3 Weeks Ago
Coreyp's Avatar
Coreyp is an unknown quantity at this point
re: Lower block oil leak: help [solved]
did you ever fix this leak? I have a similar problem, resealed the pressure switch and still leaking
Old 3 Weeks Ago
Nicocenta's Avatar
Hey! Yes I did. So the switch will actually leak through itself and you need to replace the switch. I used Honda's thread locker and torqued to spec. But yes, I resealed it as well. Full oil tank. Emptied out again. That's how I learned. New switch and you should be good
Old 3 Weeks Ago
Coreyp's Avatar
perfect thank you, just pulled it apart and your right
Old 3 Weeks Ago
Re: Lower block oil leak: help
thanks for coming back to feed back on issue and solution!
marked thread as solved
Tim1959
Aug 25, 2025 09:57 PM
7thgensurvivor
Aug 1, 2023 09:48 AM
pbruske234
Jul 8, 2018 02:21 PM
mauicivic
Nov 1, 2010 04:22 PM
