Spark Plug Installation. [solved]
Old Nov 4, 2023
New1010's Avatar
New1010 is an unknown quantity at this point
Hey guys, I'm planning to install spark plugs for the first time in my 2015 civic lx sedan. I've read that the socket used is 14mm; however, a 5/8 would be the equivalent and would work as well? Would something like this work?
Amazon Amazon
From my understanding, that tool is a socket + extender + a magnet right? Because I see a lot of videos that recommended getting all three of those items.
Another question I have is that Honda recommends Dilzkr7A11Gs while every other places recommend Dilzkr7B11Gs, what's the difference? I have emailed ngk and have not received any reply.
Edit- I was told to use a bit of carb cleaner on the plugs if they are stuck. Would brake cleaners work as well?
Old Nov 4, 2023
Colin42's Avatar
re: Spark Plug Installation. [solved]
Shouldn't need carb cleaner. Standard spark plug socket is fine. Might just be an older part number, could call honda and check
Old Nov 4, 2023
New1010's Avatar
Thank you. I don't have any spark plug sockets. I'm in the process of shopping. That's why I'm asking would that spark plug tool on amazon be ok?
Amazon Amazon
Old Nov 4, 2023
Honda OEM is DILZKR7B11GS, aka the NGK 95710.
That tool should do you just fine, too. If you already have a long 3/8" extension extension, save yourself a few bucks and just grab the socket itself
Old Nov 4, 2023
New1010's Avatar
Thank you very much.I don't have a 3/8 extension yet, that's why that tool is so attractive to me: It includes the extender, magnet, and socket all of which I don't have.
Old Nov 4, 2023
FRSam's Avatar
Click Here
I’ve used deep sockets and needle nose pliers in the past in a pinch without much issue. Those were on much tougher jobs than a civic.
Old Nov 5, 2023
New1010's Avatar
I forgot to ask you guys. Do you guys use a torque wrench to tighten to spec or do you just go by feel? Also the 5/8 socket should work in place of 14mm right?
Old Nov 5, 2023
NGK's website says it's 5/8"/16mm. Should be fine with either. 14mm gonna be too small
As far as the torque wrench goes, I do, just because I have one on hand. The torque spec is stupid low at 13ft-lbs though, so you can get away with hand tight + an extra quarter to half turn
Old Nov 5, 2023
Colin42's Avatar
Re: Spark Plug Installation. [solved]
Ngks have a crush washer, you can feel it compress as you tighten the plug
beersnob11123
Dec 21, 2022 06:58 AM
dkablack
Jan 4, 2021 11:06 AM
CBAILEY IN GA
May 8, 2018 12:01 PM
Goldenvoice
Aug 1, 2016 05:29 PM
SLeePeR012
Nov 19, 2003 06:06 PM
