Stutters and jerks at 3100rpm
Old Dec 8, 2022
merrittjr's Avatar
merrittjr is an unknown quantity at this point
2008 Hybrid. Once it hits 3100 rpms it starts sputtering and jerking. If I then try to accelerate it's as if I'm in neutral. It will rev but not accelerate. Easing off below 3100rpm stops the hesitating. If I feather it I can get up to speed. This typically doesn't happen the first 5 or 10 minutes of getting in the car. It also only happens when in drive. I can go over 3100rpms in neutral and drive. So far the CEL is not on. Any ideas?
Old Dec 8, 2022
FRSam's Avatar
Click Here
Re: Stutters and jerks at 3100rpm
I'm assuming you mean neutral and park?
Sounds like the transmission is failing. Has the fluid ever been changed?
Old Dec 8, 2022
merrittjr's Avatar
Oops yes, neutral and park. My bad. I don't *think* I've had the fluid replaced. I did a bunch of work on both of my cars last summer and I can't remember everything, but I'm almost certain that didn't get done.
Old Dec 8, 2022
FRSam's Avatar
Click Here
Your transmission like likely failing like I mentioned earlier. The fluid breaks down over time and it doesn't lubricate the gears properly. You'll need a shop to diagnose it to be 100% sure but the only solution to that would be either to replace or rebuild it.
Old Dec 8, 2022
merrittjr's Avatar
Some other info that might be helpful. First thing in the morning when it's really cold, if I put it in gear and hit the pedal it will often rev as if it's not in gear. Two or three seconds later it will clunk and then engage. However, if I coast or very lightly feather it, I won't have this issue. I don't have this issue when it's not cold out.
Old Dec 8, 2022
FRSam's Avatar
Click Here
The leans more into the transmission theory. Sounds like your torque converter is slipping.
Old Dec 9, 2022
Colin42's Avatar
Trans or torque converter is junk
lynley
Transmission
Aug 2, 2022 08:04 PM
tahoe310
Aug 31, 2020 03:11 PM
Slipstream
Jun 10, 2012 01:32 PM
yamahar6
Nov 20, 2009 07:19 PM
hotwheels
May 15, 2006 09:36 PM
