Civic Hybrid rolls back on hills.
Old Nov 19, 2009
yamahar6's Avatar
yamahar6 is an unknown quantity at this point
hey guys, i just bought a 2005 Honda Civic Hybrid. i would like to know whether its normal on CVTs to roll backward on slight inclines. it feels like its in neutral until i give a little gas. in other words if you are driving behind my you will assume im driving a stick-shift. i just changed ATF and i found some metal shavings in the drain plug. other than that car drives excellent. thank you.
Old Nov 19, 2009
Re: Civic Hybrid rolls back on hills.
its normal due to the low idle speed (for fuel economy). that happens to my 2002 gasoline civic too. unless the ground is perfectly flat, it will roll back. i usually use the ebrake to keep the car from falling and just give it a lil gas.
Old Nov 20, 2009
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
with the hybrid, isn't the engine off at a stoplight? in other words, the car isn't generating any torque until you push the accelerator. anyways, i'm sure the car isn't rolling back much compared to what would happen in a manual.
Old Nov 20, 2009
true, in many cases the engine will shut off. but there are conditions where it stays on, maybe on a sloped surface. check the rpms next time and see if its at 0.
Old Nov 20, 2009
lowlife9's Avatar
whats the big deal just keep your foot on the brake
tylerginevan
Apr 27, 2015 12:29 PM
inarschenk
South
Apr 18, 2015 04:29 PM
dooner24
Apr 14, 2015 07:51 PM
raitchison
Oct 9, 2001 08:22 PM
SILVERCASE
Sep 25, 2001 08:34 PM
