Civic 2014 EX O2 Sensor Specs
Old Nov 14, 2022
Heybeats's Avatar
Heybeats is an unknown quantity at this point
Folks,
I Was wondering if someone can provide me the resistance that's supposed to be between the heater wires for both the upstream and downstream O2 sensor?
I read different resistance values from 10-25 ohms and some that have say 5 ohms.
Old Nov 15, 2022
BrotatoChip's Avatar
Super Moderator
Re: Civic 2014 EX O2 Sensor Specs
In the '06 service manual it says 1.9-2.5 Ohms for the primary and 5.4-6.6 Ohms for the secondary heater.
Old Nov 15, 2022
Heybeats's Avatar
You don't have the 2014 specs?
My mom has a 2018 and hers show about 13 ohms across the heater wires. It's a 5 wire sensor.
Old Nov 15, 2022
Super Moderator
I do not. The manual I have is for '06-'11 8th gen Civic. Your '14 is a 9th gen which has a very similar engine. I don't know if it's the same. '18 is a 10th gen which is significantly more different from the previous years. If your '14 has four wire sensors, I would like to think the readings would be the same.
Old Nov 15, 2022
Heybeats's Avatar
I was able to use other people to get some information. Turns out it needs to be between 2.2 - 2.7 ohms. Mine is within specs.
So back to drawing board I go to troubleshoot..
Thank you for your response.
Old Nov 15, 2022
what problems are you chasing?
Old Nov 16, 2022
Heybeats's Avatar
Sorry I replied by my reply got moved to a different thread. See below.
https://www.civicforums.com/forums/3...e-2014-ex.html
Old Nov 16, 2022
Yes, I moved it - it's better if title is related to discussion.
Maybe I should have left a link like you did...
Damname
Mar 14, 2011 08:45 AM
b1995
Feb 2, 2009 09:26 PM
aznboysrfr
Feb 16, 2005 03:04 PM
HELP_ME
Sep 22, 2004 07:16 PM
blckpwdr
Oct 13, 2003 10:29 AM
