2013 Civic EX: How to get to tdc?
Old Oct 21, 2022
niemand's Avatar
niemand is an unknown quantity at this point
Is there a crankshaft bolt I can turn?
Where is it, and what's the size?
Which direction to turn it?
Are there markings to watch out for to check for tdc positon?
Old Oct 21, 2022
FRSam's Avatar
Click Here
Re: 2013 Civic EX: How to get to tdc?
Originally Posted by niemand
1. Is there a crankshaft bolt I can turn?
2. Where is it, and what's the size?
3. Which direction to turn it?
4. Are there markings to watch out for to check for tdc positon?
1. Yes.
2. On the end of the crankshaft. Accessible from the wheel well, behind the fender liner. Should be left side (LHD drivers side). Should be a 17mm.
3. Clockwise.
4. Yes.
What are you trying to do?
Old Oct 21, 2022
BrotatoChip's Avatar
Super Moderator
The 9th gen EX would have come with an R18 engine which sits on the passenger side (transmission on driver side). Slight edit to answer 2, but the other three are correct.
2. On the right side, behind the fender liner. The bolt has a 19mm head.
This pic is from the 8th gen Civic service manual, should give you an idea of what to look for.
Old Oct 21, 2022
niemand's Avatar
Originally Posted by FRSam
1. Yes.
3. Clockwise.
4. Yes.
I'm trying to inspect the cylinders for any wear (smooth spots along the wall missing cross-hatches). The seller told me he changed oil about every 5000 miles. From the spotty service records I pieced together yesterday, it looked more like every 9,000 miles. The car has 110k miles.
Old Oct 21, 2022
niemand's Avatar
What are the markings that I need to find and observe to reach tdc?
Old Oct 21, 2022
Super Moderator
I can't find anything in the 8th gen service manual. Is there any sort of arrow or mark on the timing chain cover that would line up with a mark on the crankshaft pulley?
Otherwise, just remove spark plug 1 and slide a long screwdriver in. Slowly rotate the crank clockwise until the screwdriver stops rising.
Old Oct 21, 2022
FRSam's Avatar
Click Here
I’d say do an oil change and monitor for oil consumption. That’ll be a better measure than the hassle of inspecting the inside of the block.
Phoenix765
Apr 2, 2017 12:32 PM
bluesjunky2
Oct 20, 2014 09:46 AM
trev0006
Nov 14, 2013 02:37 PM
RobCivic08
North Cali
Jul 28, 2013 04:05 AM
RobCivic08
North Cali
Jul 14, 2013 12:49 AM
