Does anybody know the oil pump mounting bolts spec?
Old Dec 12, 2021
Vincentmb615's Avatar
Vincentmb615 is an unknown quantity at this point
Installed a new head and somehow shattered the oil pump luckily I only ran it for a second and I took it back apart and found out why I didn't have oil pressure 🤣 I ordered a pump repair off eBay since the cover was fine it has 8 or 10 Phillips screw on the cover does anyone know if these have a specific spec? Or should I throw some blue loctite on it and crank them down? I would rather Know of a spec than risk cracking the cover because that assembly is twice as much as the pump by itself
Old Dec 12, 2021
FRSam's Avatar
Click Here
Re: Does anybody know the oil pump mounting bolts spec?
What year have you got? Should be in the area of 15 ft lbs but I can double check when I know more.
Old Dec 12, 2021
It is a 2006 1.8 I do know I had to use a impact screwdriver to remove them lol 😅
Old Dec 13, 2021
BrotatoChip's Avatar
Super Moderator
The torque spec is 4 ft lbs.
dazzoman
Jul 5, 2018 06:00 PM
moorebl
Jul 29, 2014 10:01 PM
tkcne
Jun 20, 2014 12:03 AM
metfan53
Apr 20, 2012 11:16 PM
EXChick
Jan 5, 2011 02:52 PM
