FN2 Cranks But Not Starting
Old Nov 26, 2021
TypeR03260's Avatar
TypeR03260 is an unknown quantity at this point
FN2 cranking but not starting, I parked the car fir an hour, when I returned it wouldn't start.
I thought it was fuel pump so changed that out but still no good.
​​​​​​No DTCs available so I'm starting to get frustrated, anybody got any suggestions what to try next?
Old Nov 26, 2021
FRSam's Avatar
Click Here
Re: FN2 Cranks But Not Starting
First suggestion would be to not fire the parts cannon at it. Engines need a few things to start, so check:
-spark (in the form of spark plugs or ignition coils)
-fuel (injectors, plus make sure your fuel pump is actually priming. Could be something as simple as a blown fuse)
-air (a gnarly enough vacuum leak will cause a no start, among other things)
-compression (unlikely but wouldn't hurt to check)
-timing (I'd leave this last because it's almost certainly not this)
With regards to codes, is the check engine light not on or have you actually used a scan tool? There are sometimes stored codes in the computer even when the light is off.
RotorBeav15
Jul 10, 2017 11:51 AM
93Civiceg
Oct 30, 2016 04:56 PM
buc18
Oct 5, 2014 05:30 PM
heydude111100
Nov 16, 2011 07:24 PM
gearbox
Engine start problems
Sep 27, 2006 03:45 AM
